Another alternative to getting brighter gauges
I know we've had a very long thread going in regards to brighter gauges. In that thread many ideas have been thrown around, mostly focusing on LED options. We've pretty much ruled out the LED replacement bulbs, though they produce a different light, as they don't really make it easier to read. LED strips seems to be a good option, though not all that easy for a DIY. Halogen replacement bulbs increase light but may over drain the wiring harness.
Here is the option we are discussing on the XKE's Smith gauges that illuminate a similar way to our VDO's. Here is the link below, though it is further discussed in later threads. Cheap and seemingly functional plus reversible. http://forums.jag-lovers.org/tv.php3?eNotkEsKwkAQRG+TnTCd/gdyGMEsslFRF3p7YapWj57+vGIer3M/77fju1z34/L5PY/lvYu0mvo2aUIG6CvJfrCOJBtMIwusATb2fGDPZZAKKmv6XeF1R w7vIuEJgTdW1swbhf0UeHLFXPJ+KvKl470EnuZcB+50zlw24LG h028yyAC9p8cC/2Mltf0BZx9LKQ== I tried the above link by copy/paste and it worked fine on my browser.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Member 911 Anonymous
Whoa, Nice. Does it dim as well?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
So the right one is the orignal Guage without the El-Tape?
Well, I think I will experiment on my spare clock, GREAT FIND!!! I found the white tape and will post when done.
coolcavaracing.com
Nice...
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
I tink the right one is the original speedometer "guage" without the tape, not a second tachometer.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
EMT/TechRescue Instructor
I think I just found my next project.
Thanks Luke!
David 1986 Iris blue 911 Cabriolet 2017 Ram 1500 Night edition 2025 BMW X-5 |
So how do you find this stuff? mutantmods.com takes me to a site called startech.com, where a search for "electroluminescent tape strips" brings up nothing.
___________________________________________ 2001 Boxster S, Orient Red Current Vehicle, 1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**, 1971 911T **Sold**, 1968 912 **Sold** |
Throw it on the ground!
Here are some links. Subscribing to follow trail blazers on this one. Could be interesting!
http://world-electroluminescent.com/new_EL_products.html http://www.tapesolutionsinc.com/photoluminescent-tape.html This is photoluminescent tape (glow in the dark) ![]() This one looks promising: http://electroluminescence-inc.com/ELtape.htm Automotive applications here: http://www.glowhut.com/electroluminescent-strip--el-tape-set-with-car-lighter-plug.html http://www.youtube.com/watch?v=RkU_0dZZVu0 http://www.aircraftextras.com/EL-Panel1.htm Dash lighting project using electroluminscent tape: http://www.imperialclub.com/Repair/Electrical/EL.htm http://www.teamchicago.com/imperial/imp-el.htm
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I found a company that sells white El tape for those that don't want the Disco effects. I will post later.
Apparently not as popular because it emits a light blueish tint like most LED White light do. I wonder why they can't make White, is it because it isn't really a color inversely black has no color or absorbs color? Just notice the Jag owner also used Green Blubs too.
I would rather be driving
I like this better than the LED.
The reason LED and EL materials have a bluish tint is that they rely on phosphors with Red, Green, Blue mix to fit the entire spectrum. Each has a different efficiency and it is hard to fill a full visible spectrum with three overlapping colors. Generally, the lower wavelength, higher energy colors (violet, blue, green) are more efficient at energy conversion.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
AutoBahned
looks like a very clever trick
I wonder how long before the tape unsticks itself and peels away from the rim? |
Slumlord
One sight suggest using silicone to attach it. I doubt that would ever come off.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
yep, im slow in the head
that looks like a nice upgrade
This company claims to have Brighter El Wires in 3.2 & 5 MM sizes in WHITE:
http://www.elec2go.com.au/category13_1.htm Yeah I think the tape will lose it's adhesion over time and heat. The wire would keep it's shape but would need to be silicon (RTV) down I suppose. Will play around with my spare OEM Clock to see.
Yes the Tach on the left is modified vs. stock (old) speedo on right. I'm glad others found this as informative as I did. I've been thinking about doing something and this seems the best and still affordable even with the added inverters.....simple. Gives a more authentic appearance than the LED and barring some silicone, no mods to housing. Unlike the E-types, our 911's are unlikely to bring a 100k unless its a RS so modd'n the gauge housing isn't quite as scary. On the flip, the XKE is certainly costing me more to restore too
Hey Luke,
Do you know if one needs a inverter per guage or is there way to use one inverter and in our case 5 El Wire/Tapes connected to one power source and ground. Can't imagine this device drawing that much current anyways.
