Bill Verburg's Avatar
Phase 4, done :)
Phase 1, RS Aerokit
Phase 2, RS brakes
Phase 3, G50/30 Cup transmission
Phase 4, Full JIC Comp suspension, TRG adjustable bars, lowered, corner balanced, Unbelieveable handling
Bill Verburg
Old 09-01-2006, 06:25 PM
Don Plumley's Avatar
Woo Hoo! Glad to see the JIC's finally mounted and set up!
Don Plumley
M235i
Old 09-01-2006, 07:05 PM
Me too
Bill Verburg
Old 09-01-2006, 07:08 PM
Silveresrty911S's Avatar
WOW Bill!
She looks great, I bet it handles better.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 09-01-2006, 08:29 PM
The difference is night and day, I was somewhat concerned tht the monoballs would make the ride too harsh for street use, but that is not the case at all.
Bill Verburg
Old 09-03-2006, 08:06 AM
Tom W's Avatar
Bill: It looks great! I'm in the process of going to full monoballs. Had the rear changed before the last race and it was much more planted. The front is being done now. I can't wait to get it out again at the end of the month - I also am having EVO uprights installed with a bump steer package - and want to see how much that helps (it darn well better eliminate the problem).
Did you opt for the mid range JIC springs or the firmest? I had the mids for the last 3 years but am at the point now where they are too soft and will be going to more firm springs too.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 09-03-2006, 10:16 AM
Thanks tom, I went w/ the 7/10(392#/560#), 8/12 are still on the shelf. Your skill set is way beyond where I am.
I thought about the EVO kit but thought I'd ty this first.
Biggest problem so far is that I had to raise the ramps on my lift a full inch to get the car in the garage.
Bill Verburg
Old 09-04-2006, 02:27 PM
spring rate discussion
JIC 7/10 linear
N/mm kg/mm lb/in
68.7 7 392
98.1 10 560
JIC 8/12 linear
N/mm kg/mm lb/in
78.5 8 448
117.7 12 672
993RS progressive
N/mm kg/mm lb/in
43 4.4 246
80 8.2 457
GT2 light
N/mm kg/mm lb/in
270 27.5 1542
296 30.2 1690
GT2 stiff
N/mm kg/mm lb/in
320 32.6 1827
350 35.7 1999
M030 progressive
N/mm kg/mm lb/in
26.3/35 3/4 150/200
39/48 4/5 225/275
Bill Verburg
Old 09-04-2006, 02:48 PM
PorscheGuy79's Avatar
Simply...perfect.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 09-04-2006, 05:20 PM
Tom W's Avatar
I'm not sure that I'm all that good, but I'm getting better all the time and having a great time doing it!
I'm likely to start at about 600/800 and see how it goes. I'm starting to push pretty hard and am having some issues with the bias ply slicks in the rear. The guys at the shop believe I'm weaing the inside edges excessively due to changes in toe with suspension travel. They will be removing the springs and raising and lowering the car with a jack to determine the changes in toe and camber through the suspension range. It is believed that simply reducing the amount of range in the suspension will help.
With the switch to monoballs in the rear I've reduced the amount the slicks are rolling onto the sidewalls (despite proper pressures). It made a significant difference in the grip. I'm hoping the front goes as well. I'll know in a couple weeks as I have a 3 day weekend at the track coming up.
Tom
Old 09-04-2006, 05:28 PM
Why aren't you using radial slicks?
Bill Verburg
Old 09-05-2006, 05:47 AM
kang's Avatar
GT2 stiff
N/mm kg/mm lb/in
320 32.6 1827
350 35.7 1999
Yowsa! At that rate, why bother with springs at all!
Downshift
Old 09-05-2006, 08:23 AM
Tom W's Avatar
Bill: Class rules require the Goodyear R600 compound slicks in 10.5x23.5x16 and 13x25x16 sizes. That way we all run the same tires and they last 2-3 weekends. The class is desined to limit hp (to about 300 due to running stock intake), weight, and handling (tires) to even out the cars and differentiate the drivers.
Tom
Old 09-05-2006, 09:50 AM
DW SD's Avatar
SWEET! Great job - really looks outstanding! Your 3.8 would suit that very well!
Doug
1971 RSR - interpretation
Old 09-05-2006, 10:02 PM
Very nice. I'm considering the CROSS setup.. any thoughts? Also.. those wheels. I hesitate to ask what they are because I liekly don't want to spend that much money but sheesh.. those are just nice! Cool ride!!
- David
Bremerton, WA
1992 500E
1990 964
various motorcycles
Old 09-08-2006, 08:51 AM
IMO JIC Cross is the only way to go,
* great selection of springs
* monoballs and camber plates are included
* adjuster is more positive than PCCB
* ride height and corner weight are independantly adjustable
The rear drop links are a bit of an issue w/ TRG sways
Bill Verburg
Old 09-08-2006, 11:52 AM
What suspension did you have on there before? If it's Bilstein or the M030 spring, I am interested.
thanks,
anthony
Old 09-08-2006, 12:58 PM
I took off ROW M030/Monroes and ROW M030 sways
Bill Verburg
Old 09-08-2006, 01:33 PM
I am interested in the package. Give me a call at 214-783-6678 if it's available.
thanks,
anthony
Old 09-08-2006, 01:53 PM
thanks,
anthony
I haven't decided what i want to do w/ them yet.
Bill Verburg
Old 09-08-2006, 03:14 PM
