Bill Verburg's Avatar
Phase 5, Done
Phase 1, RS Aerokit
Phase 2, RS brakes
Phase 3, G50/30 Cup transmission
Phase 4, Full JIC Comp suspension, TRG adjustable bars, lowered, corner balanced, Unbelieveable handling
Phase 5, 3.8RS installed in '95 coupe
Weather finally broke, finally got a chance to play w/ phase 5, Ausgezeichnet!!
Bill Verburg
Old 03-13-2007, 09:31 AM
kang's Avatar
Sweet
Downshift
Old 03-13-2007, 09:52 AM
Sports Purpose 911 Driver
mjshira's Avatar
nice work Bill.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 03-13-2007, 06:02 PM
Tom W's Avatar
But, but , but ... it has AC in it! You figure the 3.8 has the extra power to run it in a race too? Thank god the class rules prevent me from doing a 3.8. I have to live with a 300 hp putt-putt rthat's a bit over-weight.
It looks great. Our 70's and sun have made me yearn for track dates and I have to wait another couple weeks before getting back out again.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 03-13-2007, 09:48 PM
Don Plumley's Avatar
WOW! I'd love to go for a ride one day...
...or maybe it would be a lot better for my wallet if I didn't.
Don Plumley
M235i
Old 03-14-2007, 11:36 AM
heat too, It's not a race car. This is what they should have been Day1 at least as an option.
Bill Verburg
Old 03-14-2007, 05:09 PM
Love to have you, none of this is cheap.
Bill Verburg
Old 03-14-2007, 05:11 PM
bigchillcar's Avatar
looks like the heater blower has been removed though. nice, bill.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-21-2007, 12:30 PM
cupcar#12's Avatar
nice bill
I need a /30 for my car
59 356a Coupe
Old 03-22-2007, 11:10 PM
mp3 in the garage
Bill Verburg
Old 03-27-2007, 01:06 PM
mjshira's Avatar
solid lifters?
Old 03-27-2007, 01:30 PM
mjshira's Avatar
drop me an email Bill, have some pics of a Timmons based exhaust I did to share with you.
Old 03-27-2007, 01:31 PM
Originally posted by mjshira
solid lifters?
No, stock hydraulics
Bill Verburg
Old 03-30-2007, 02:43 PM
mjshira's Avatar
was there any difference between hydraulics? were they all the same part number? I see to have damaged mine by running 15/50 oil. I have lifter tap, no too bad, but enough to be annoying.
Old 03-31-2007, 08:40 AM
there are 3 lengths of hyd. lifter. The longer ones are only used if the valves seats are moved from the standard stock position possibly be a valve job or seat replacement.
15/50 shouldn't have caused an issue. They are wear parts w/ the polymer seals being the most fragile parts
Bill Verburg
Old 03-31-2007, 02:50 PM
Fantastic! Nice work. IMO Your car is the ultimate especially the color.
Old 03-31-2007, 10:00 PM
mjshira's Avatar
thanks Bill. the way Tyson built the engine, we ran ti springs, etc. we had the heads done with valve angle and guides. I replaced all the lifters and within 3,000 miles I have noticable lifter tap, when I listen to other 993 engines I don't hear this noise. I am driving it now with 0w40. What do you think would be the right one to run? I even considering solids thats how much I want to address this issue.
Old 04-01-2007, 08:21 AM
993.105.141.05 is stock
993.105.141.51 is size 1
993.105.141.61 is size 2
Stock intake spring height for an M64/05 - 08 is 36.7 +0.3mm, exhaust is 35.7+0.3mm
which version you need depends on the difference your spring height is from stock
I don't know the actual length of any of them, You will need to find that out and choose acordingly.
Bill Verburg
Old 04-01-2007, 09:49 AM
mjshira's Avatar
thanks Bill. I will find out the height of mine and see what this means. Big help, I appreciate it.
Old 04-01-2007, 06:13 PM
flat6rs's Avatar
Could we have more pictures of you car? Exterior shots would also be nice... Are those original Speedline for Porsche wheels?
Incredible car and cool color, Bill.
Old 05-15-2007, 11:40 PM
