Bill Verburg's Avatar
Phase 7
Well I've started the ball rolling on Phase 7, which will be to update the rear suspension to RS spec
for reference here is Phase 1
last year in phase 6 I did the front Rs uprights and second GT2 oil cooler
Phase 6
parts ordered so far
993.331.045.80 Kinematic Control Arm x2 RS, top rear
900.067.323.09 M12x1.5x90 hex head bolt x2 K/T inner
993.331.219.01 eccentric washer x2 K/T inner
999.507.384.09 M12x1.5 nut x2 K/T inner
999.084.449.09 VM12x1.5 nut x2 K/T outer
993.331.041.81 A arm /L x1
993.331.042.81 A arm /R x1
900.378.052.09 M12x1.5x80 hex head bolt x2 a/a trailing
999.084.445.09 VM12x1.5 nut x2 a/a trailing
900.378.051.09 M14x1.5x100 bolt x2 a/a leading
900.380.012.09 VM14x1.5 nut x2 a/a leading
900.380.009.09 VM12x1.5 nut x2 a/a ball joint nut
993.331.047.03 Camber control arm 96- x2 not RS specific, top forward
993.331.217.80 Eccentric screw x2 c/l, top forward inner
993.331.219.80 Eccentric washer x2 c/l, top forward inner
999.084.445.09 VM12x1.5 nut x2 c/l, top forward, inner
999.084.449.09 VM12x1.5 nut x2 c/l top forward outer
the difference between the early 993 supension, later 993 suspension and RS is in the stiffness of the bushings, mine will be set up for min kinetic-toe intrusion
The stiffest bushes are used on the RS and can be identified by the green dot, same as used when identifing the RS sway bar bushes
Bill Verburg
Old 10-30-2008, 02:15 PM
Don Plumley's Avatar
Green (dot) with envy again!
Don Plumley
M235i
Old 10-30-2008, 03:12 PM
Says the guy w/ full ERP rear suspension
Bill Verburg
Old 10-30-2008, 03:24 PM
Yeah, the world's most expensive turnbuckles.
I like where you are going with your approach. Starting to work on my winter punch list as well, but not nearly as in-depth.
Don Plumley
M235i
Old 10-31-2008, 10:19 AM
Manassas, VA
lucittm's Avatar
Bill,
Are you, or have you removed the rear wiring harness for the ABS and pad wear sensors? If so, I could use two of the rubber grommets that secure the harness to the chassis as shown below. I cannot find a Porsche P/N in the PET.
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-31-2008, 01:30 PM
Originally Posted by lucittm View Post
Bill,
Thanks,
Mark
Mine is a 993 and i'm keeping all of those parts
Bill Verburg
Old 10-31-2008, 01:53 PM
Manassas, VA
lucittm's Avatar
Bill,
I take it from your answer that the 993 uses the same grommet on the wiring harness. Any thoughts on how to obtain a P/N for the grommet? Is it worth a trip to the dealer with the picture above? Is a Porsche graveyard my only hope?
Thanks,
Mark
Old 10-31-2008, 02:13 PM
Mark I just looked all over the 964 PET and did not see that grommet listed. That does not mean it is not a part, but it could be part of the harness assy.
Don Plumley
M235i
Old 10-31-2008, 03:14 PM
Look up 964.612.185 - I don't see a picture of it, but this is the rear brake harness, I bet the grommet is part of that...
Don Plumley
M235i
Old 10-31-2008, 03:17 PM
Grommet is part of the harness...I picked up a used set from a 944, cut them off and added them to my lines...
Old 10-31-2008, 03:33 PM
Manassas, VA
lucittm's Avatar
Don,
Thanks. (Sorry for the thread hijack) I searched PP for 964-612-185-00 and did see a listing for a "Brake wear harness" for $311.50. I'll keep my eyes open for a used, burnt, or broken one to get a pair of those grommets. Since Turbo3.6 found some on a 944, it seems they are common to several models.
Thanks,
Mark
Old 10-31-2008, 08:34 PM
This is the target area
Bill Verburg
Old 11-03-2008, 04:33 AM
Here it is $2000 worth of 993RS rear suspension
let the games begin..
I cannot believe how light these things are
Bill Verburg
Old 12-03-2008, 04:02 PM
Aside from the harder bushings, is there any difference?
Old 12-03-2008, 06:31 PM
Sweet!
Don Plumley
M235i
Old 12-03-2008, 06:49 PM
A friend did this job last year, he couldn't find any geometric difference. As I proceed I'll certainly be looking to see differences but as the fellow that did it already is an extremely meticulus sort, I don't expect to find anything.
Bill Verburg
Old 12-04-2008, 02:45 AM
Some more pics of the arms before installation
Bill Verburg
Old 01-13-2009, 10:51 AM
None that I can see, but putting them side by side will be the telling test.
The weathers been brutal here, so no progress
Bill Verburg
Old 01-13-2009, 10:52 AM
What a long miserable winter
More parts
solid rear suspension inner mounts
Upgraded front monoballs & camber plates
Bill Verburg
Old 02-23-2009, 01:11 PM
Started the dis-assembly
step 1 drop the rear suspension to replace the side-mounts, 4 bolts( and a few smaller ancillaries and shes down
The bushes on my rubber mounts were corroded to the al. sidemounts some effort was needed to pop them out.,
The new ones slide in easily
Bill Verburg
Old 02-25-2009, 02:23 PM
