I would rather be driving
jpnovak's Avatar
Project ITBs: mock-up
I was lucky enough to have some parts cut this weekend. A good friend hooked me up with some CNC mill time and cut these great plates for the base of my throttle body project.
The plates are a press fit to the tubing I will use as my runner. It has a 41mm ID and closely matches the GSXR throttle bodies. Here are a few shots of the mock up. Next step, get out the welder.
Old 11-30-2004, 07:14 PM
jpnovak's Avatar
Oops! forgot one.
Old 11-30-2004, 07:15 PM
Somewhere in the Midwest
MotoSook's Avatar
Nice work Jamie! NICE!
Old 11-30-2004, 07:16 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Jamie,
Will those mount directly to the heads or will you have some sort of manifold between the ITB and heads?
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 11-30-2004, 08:51 PM
So you're putting motorcycle carbs on your 911?
Old 11-30-2004, 09:01 PM
sammygon1's Avatar
Looks good, any luck on the linkage yet? Sam
Sam Gonzales
'69 912 2.0 -6 power
Old 11-30-2004, 09:03 PM
jpnovak's Avatar
Thom, Here are the two links previous. Souk is putting MC carbs on the 911. These are fuel injection throttle bodies. Yes, they are from a motorcycle. Cheap, easy to find and allow individual throttle bodies for my EFI conversion.
Project ITBs: Part 1-parts arrive
The current design has them bolting directly to the heads. I may modify this to mount on weber manifolds.
Sam, I have a design in mind for linkage. Once I get a set of 3 mocked up I can see if it will work out.
Old 12-01-2004, 06:49 AM
Mike Bonkalski's Avatar
Very cool Jamie. I am very interested in how you linkage turns out.
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 12-01-2004, 07:01 AM
ValveFloat's Avatar
Very cool. I've been following your project. How will the TB attach to the tube?
Joe
1993 C2
Old 12-01-2004, 07:59 AM
jpnovak's Avatar
the TBs will eventually be welded to the tube. I will likely clamp a rubber sleave to do some testing with intake length.
Old 12-01-2004, 08:27 AM
jmshepard's Avatar
Jamie,
This is great work. I have started winter project along the same lines. Just so I don't reinvent the wheel (incorrectly), would it be possible to post the dimensions of the plates that the CNC machine used for the milling? A CAD file in a .dxf or .dwg format would be even better.
Thanks in advance,
Jim S.
Old 12-01-2004, 04:12 PM
