keithdog72's Avatar
Send a message via AIM to keithdog72
Question Ignition Troubleshooting??????
I am having some trouble getting my 75 2.7 to run properly. I am getting fuel and the CDI box is fine. The engine will fire intermittently and then die. I am fearing a bad coil. I would like to know when I should be getting power to the coil and where? Should the +terminal be getting power with ignition on? what about the -side? I have rechecked the ground points and everything seems to check out. What am I missing? This has to be something simple, as the engine will fire sometimes. Please help, I am getting frustrated TIA
Keith
1975 911 Targa
1972 VW Beetle
2004 Mercury Mountaineer
2003 Suzuki Intruder 800
Old 04-14-2004, 10:41 PM
Lorenfb's Avatar
With the CDI system, there's no power at the coil. You probably have a fuel related
problem. Check out this web site (www.systemsc.com) on the Diagnostics page
under "No Start".
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 04-15-2004, 07:43 AM
Dirty points?
Old 04-15-2004, 03:21 PM
keithdog72's Avatar
brand new set of points
1975 911 Targa
1972 VW Beetle
Old 04-15-2004, 03:24 PM
Early_S_Man's Avatar
Porsche Crest
Keith,
Same suggestions I have made a dozen times in the past month ... remove electrical panel, then CDI, clean grounds, 14-pin connector, 3-pin connector & braided gound cable-- crimp sides of individual Faston connectors, remove double-ground tab on CDI unit box ... wire brush & clean with Brakleen & then apply silicone grease when tab reinstalled, remove & clean power wires at 3-position fuse block, etc., etc. ... and apply silicone grease at CDI unit connections after proper operation is verified!!!
Do bench check of CDI system with new wiring in a test jig as suggested in this latest thread:
no start questions??
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-15-2004, 03:47 PM
Senior Member
Superman's Avatar
Huh? Did you say something, Warren?
Mocha 1978 911SC. "Coco"
Old 04-15-2004, 04:03 PM
Porsche Crest
Supe,
... basically, I think I said the wiring and connectors in these cars are showing their age and need a bit of oxidation cleaned off ...
... BEFORE you start spending big $$$ to replace coils, install MSD, etc. ...
People ASSUME that wiring, coil, CDI needs to be replaced, AND, sure enough ... when they do that the car runs much better!!! Of course they have a pile of perfectly good parts, in most cases, lying on the garage floor, or in the trash ... that only needed to be cleaned, tested, re-connected with Dow Corning 4, 111, or 112 on all of the connectors ...
BUT, doing the dirty, slow, & tedious work doesn't have the 'glamour' of new wiring and a new MSD, now does it???
Naw ... forget what I said! It's more fun to spend lots of money and brag about how GREAT the car runs after the so-called 'upgrades' ...
Warren Hall, Jr.
Old 04-15-2004, 04:16 PM
dtw dtw is offline
GAFB
Warren, sometimes I wanna switch professions, become a pharma salesman, and sell you some Prozac. I could make a killing. You are one fired-up dude, but I wouldn't change a thing. Rock on!
Several BMWs
Old 04-15-2004, 04:30 PM
keithdog72's Avatar
Just cleaned everything really thouroughly. All the ground points and all the connectors. I am starting to think that this problem could be fuel pressure related as the car WILL fire and then it dies. I pulled an injector and got ALOT of pressure. So I guess I can rule out the Fuel Pump. Not really sure what happened to my baby. Any advice is helpful.
1975 911 Targa
1972 VW Beetle
Old 04-15-2004, 05:33 PM
Lorenfb's Avatar
Warren is right on. Don't waste money until you understand and solve the
problem. The problem is still undefined.
Try moving the sensor plate when starting the car to add more fuel or
spray some carb cleaner into the intake when it starts to die.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 04-15-2004, 09:17 PM
keithdog72's Avatar
ok, dumb question which way should I move it to add more fuel?
1975 911 Targa
1972 VW Beetle
Old 04-15-2004, 09:48 PM
