-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Please post your non-930 turbo builds. (http://forums.pelicanparts.com/showthread.php?t=1008806)
Geronimo 10-07-2018 11:01 AM
LOL, threads like these really drive home how much I don't belong in a Porsche... I'm a few hundred grand a year shy. lol.
clutch-monkey 10-07-2018 02:47 PM
wow that is sweet.. where did you shift the oil tank to?
GJF 10-07-2018 02:57 PM
http://forums.pelicanparts.com/uploa...1538949271.jpg
This is how I originally set it up. But when they started putting Ethanol in gas it destroyed the bladder in the fuel cell.
GJF 10-07-2018 03:04 PM
http://forums.pelicanparts.com/uploa...1538949800.jpg
This is how it is now after I end up fabing a simple tank. I will eventually build a more detailed tank to fit the original location.
Ollies930 10-09-2018 02:34 PM
Did you do anything inside the tank to prevent fuel sloshing away from the fuel pump pick up on hard decceleration or turning?
GJF 10-09-2018 02:43 PM
Yes, I put baffles with a sump below centered. I didn’t know how long it would stay in the car, but atleast I built it right.
Ollies930 10-10-2018 09:47 PM
I don't suppose that you have pictures of that?
baloo 10-11-2018 04:45 AM
Turbowerks scavange pump
Originally Posted by Rodsrsr (Post 10196124)
... I didn't have luck with the gravity drain so I'm using a Turbowerks scavange pump which does a great job. ...
Rodsrsr - Interested how you plumbed your Turbowerx scavange pump -- where did you hang the pump? Did you go back into the engine sump plate? Any pix?
THX
baloo 10-11-2018 04:53 AM
Originally Posted by IROC 912 (Post 10196214)
Mine is mild with alot of bolt ons ... US 3.2L, stock rebuild, 930 j pipe, Tial F46, AEM Infinity 6, COP ignition, Bosch 044 pump, 60lbs injectors, Treadstone custom intercooler and GT3076R turbo.
http://forums.pelicanparts.com/uploa...1538013327.jpg
IROC 912 -- Is that fan on your intercooler a puller or a pusher? Is it constantly on, or is there a thermo-switch or somehow tied to some other engine control?
THX.
x
GJF 10-11-2018 05:00 AM
Sorry Ollie, I didn’t take any pics during fabrication as I did it as a temporary fix that has been in there for several years. Eventually
I´ll get to fabricating a new tank that will resemble (in shape atleast) a factory tank with added capacity.
Tippy 10-11-2018 05:43 AM
Man, I'd love to feel the pull of your car, GJF! Bet your cheeks feel like they getting pulled back even! ;)
IROC 912 10-11-2018 08:12 PM
THX.
x
The fan is a SPAL pusher, Infinity ECU turns it on when intake temps reach 26 deg C and shuts off when intake temp gets to 23 deg C. It only comes on during a hard run through the gears, then shuts off after a few minutes. I've never had the intake temp get much above 28 deg C this summer.
baloo 10-12-2018 04:48 AM
Thanks, good info. So, you can adjust the on-off thermostat switch too?
IROC 912 10-12-2018 05:01 AM
I'm not using an on-off thermostat, but the switch points are configurable within the ECU tables.
Geronimo 10-13-2018 10:14 AM
You bastards have done a very good job of planting a boost bug in my brain.
Sadly the question becomes do I boost and wide body the SC, or build a fun lil Cobra replica... oddly enough they would cost the same.
Rawknees'Turbo 10-13-2018 10:30 AM
:eek:
Sounds way kinky, JustTheTIPpy!!!
Rodsrsr 10-13-2018 11:51 AM
THX
Its just mounted near the overflow tank and the oil returns on top of the engine. (no sump plate 3.2) I once had it mounted in the engine bay but when I moved it close to the overflow tank it worked much better.
gavinc69 10-28-2018 02:34 PM
1980 911 SC Euro 8:6:1
Rebuilt with :
993 Cams
993 Headstuds
RS Cut Valves
Port And Polished Heads
EFI Upgrade :
3.2 Carrera Intake
Siemens Deka 80lbs Injectors
Omex 710 Series ECU (Fuel & Spark Control)
Going Super Fast Crank Wheel Kit
Turbo Hardware :
K27-7200 Turbo
Custom Almost Full Bay Intercooler
TurboWerks Oil Scaveneger
OBX Headers (Modified To Remove Wastegate Restriction)
Tial 46mm Wastegate
Made 320 crank HP and 280ft lbs :( but since found the guy that did the EFI is an idiot and very poor workmanship, so going somewhere else for a retune.
Also found whilst doing a 915 rebuild last week the head studs are not torqued correctly which is why one side was leaking oil. Now fixed and hopefully a bit more compression :p
Will be getting a GT30R or getting the K27-7200 upgraded to a hybrid soon.
http://forums.pelicanparts.com/uploa...1540762128.jpg
http://forums.pelicanparts.com/uploa...1540762181.jpg
http://forums.pelicanparts.com/uploa...1540762285.jpg
http://forums.pelicanparts.com/uploa...1540762352.jpg
http://forums.pelicanparts.com/uploa...1540762366.jpg
Geronimo 10-29-2018 08:16 AM
Thats cool, a lot of nice work without being crazy highend cost bits.
flat6pilot 10-30-2018 03:26 PM
Cobra
Sounds like you should just do the Cobra replica and be done with it. Should only cost around $40k give or take. Depending on how high or low end you go.
