Work in Progress
Rich76_911s's Avatar
Hard stop under boost
Hey guys,
I'm running into an issue on my recently rebuilt engine.
It's running well off of boost and builds boost slightly up to about .5 bar, but once I hit 0.5 bar the engine just suddenly hard stops.
I noticed on one occurrence that the AFR meter hit 20 when this happened.
I did replace and test the new overboost sensor which seems to be functioning as expected.
However, I'm wondering if I may have caused this issue by using a silicone elbow to connect the intake air pipe to the turbo. Some idiot (yeah me) cut the intake pipe and I used this elbow to "repair" the hack job cut I made.
Do you think this elbow is collapsing (See photo with arrow) when boost builds up and is causing a major lack of airflow through the engine? Or am I on the wrong path in thinking this could be the culprit and should be looking into the yellow overboost relay?
Really want to be out on the road putting some miles on it this fall!!
* *Sorry photo isn't loading at this moment will try again later**
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-04-2021, 07:48 AM
greglepore's Avatar
Try running it on a brief run without the elbow and see? But I suspect its something else.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-04-2021, 09:05 AM
Work in Progress
Here is the photo:
Old 10-04-2021, 09:15 AM
Work in Progress
Greg - I am running CIS and I don't think I could run it without that elbow, otherwise the metering plate wouldn't see any airflow and would be closed at all times. Resulting in no fuel.
But maybe I am misunderstanding your suggestion.
Old 10-04-2021, 09:18 AM
greglepore's Avatar
Ok. Didn't realize you were on cis and that the metering occurs upstream of the elbow. But I find it hard to believe that you could create enough of a vacuum there to suck the hose shut.
If its leaking elsewhere that would also account for a crazy high afr, as the metering unit would see giant airflow but none would actually be reaching the intake...
Greg Lepore
85 Targa
Old 10-04-2021, 10:08 AM
speednme1's Avatar
Rich I had a similar issue. Turned out to be a bad fuel pump relay(although it was new). I replaced it with the old relay and the issue went away.
Rey....77 930 "the Mistress"
Old 10-04-2021, 10:20 AM
Work in Progress
Thanks Greg - I wish I was running EFI
Thanks, Ray that is an easy fix if that is all it is. I have a couple of those lying around from various cars I've taken apart over the years.
Old 10-04-2021, 11:02 AM
Banned
DOOD! YUUUUUGE CONGRATS on getting back on the road brohammage!
WELL DONE!
Hope this fix is something simple for ya...
Old 10-04-2021, 11:25 AM
Work in Progress
WELL DONE!
Thanks, amigo. If you want to make some money buy whoever sells Zanax cause I'm going to need an IV of that stuff in constant supply Gonna take me a while to get comfortable with this build even though I've been about as anal as I can get.
Old 10-04-2021, 12:42 PM
mark houghton's Avatar
Me, I would at least try grounding out the wire to the overboost switch....even though you have installed a new switch, it could be defective. At least take that possibility out of the equation.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-05-2021, 06:15 AM
Crotchety Old Bastard
RarlyL8's Avatar
This is classic overboost switch malfunction. New part means nothing today, cheap crap everywhere.
Old 10-05-2021, 06:52 AM
Work in Progress
Thanks, Mark and Brian. I'll give that a shot and report back. Might not be until the weekend that I can tackle these things.
Old 10-05-2021, 08:06 AM
Turbofrog
smurfbus's Avatar
could also be the first elbow on the metering plate. Mine did that.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 10-05-2021, 09:42 PM
Work in Progress
All ya all that guessed overboost sensor win the prize. Grounded it out and the car built 0.7 bar without a problem. Thanks for all the suggestions. Good news is it’s a relatively easy fix.
Only issue left is that I’m getting some smoke out of the turbo / oil line connection.
Old 10-07-2021, 02:20 PM
Great news! It's usually the simplest things.
Old 10-08-2021, 08:25 AM
Hope it’s not the line from the breather area to the turbo. That one would be a beeyotch to get at with the intake and etc on the engine. Is it new?
Ken
1986 930 2016 R1200RS
Old 10-08-2021, 09:31 AM
Work in Progress
Hey Ken. Yeah that’s the line. Fortunately I got one from Turbokraft that is a flexible line.
I’m pretty sure it’s just not tight enough. I added a GT-35r turbo and there is an oil restrictor at that junction. I imagine the oil pressure is quite high behind that restrictor and that’s where I’m leaking. I just have to tighten it down some more, I hope.
Going to make a better ground for that overboost switch and take it for a longer test drive today. Also need to wash 3 years of dust off the car.
Old 10-09-2021, 04:11 AM
