Happiest when Tinkering
gsmith660's Avatar
mahles were on sale hard to pass up
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-31-2024, 06:12 AM
Banned
I think that's a great platform to start with.
Old 09-02-2024, 07:46 PM
gsmith660's Avatar
Jut got off the phone with the machinist and we have pretty much finalized the plans for this engine and it will be bulletproof top people are working on the part Pauter and dockerty are doing cams and connecting rods/rocker arms the heads will go out in a month or so for twinplugging then come back for reassembly at Noland's then it is just small parts acquisition an final reassembly to a long block. Just need money LOL. One note is I had 11 head studs broken off in the case and he told me 3 are out and it looks good for the rest to come out fairly easy it is taking time because he had to move his shop and the holidays but i am not in any hurry just want it done right.
Old 11-20-2024, 08:13 AM
gsmith660's Avatar
The tear down in progress the inside so far looks good after 15 years of running boost I suspect I spun a bearing so this 2.7 isn’t worth a rebuild so it will become a coffee table and the crank will be an end table
Old 11-20-2024, 01:07 PM
gsmith660's Avatar
The cause of the failure has been found both intermediate shaft bearing were wiped down to the copper the mains and rod bearings were rough but still had babbit crank looked pretty good will make a nice end table.
Old 11-30-2024, 04:34 PM
gsmith660's Avatar
All broke down the case is a mess and not worth a rebuild the crank and intermediate shaft bearing surfaces are scored. The only stuff maybe worth while are the con rods and the oil pump is rebuildable.
Old 12-04-2024, 10:04 AM
Grappler
Rodsrsr's Avatar
At this point might as well get some new rods anyway.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 12-04-2024, 12:01 PM
gsmith660's Avatar
First part from the old engine repurposed as a lamp for the end table
Old 12-09-2024, 01:17 PM
flat6pilot's Avatar
Hows the build going?
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 12-15-2024, 08:44 PM
gsmith660's Avatar
The heads are broke down gone for twin plug the cams and rockers have been sent to get refurb and new profile the crank is checked and polished and the case is getting worked to get the head studs out. I am getting the new parts bought as money allows.
Old 12-15-2024, 09:09 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
No Commitment, Just Pleasure: Connect with Local Ladies in Your Town
Find Women Who Want to Enjoy Life Tonight in Your City
Supreme Сasual Dating
https://datingnow.site
Old 12-15-2024, 11:09 PM
um....
Always learning.
www.aircooledporsches.com.au
Old 12-16-2024, 03:47 AM
Great Work!
Old 12-19-2024, 10:48 AM
gsmith660's Avatar
The finished end table
Old 12-20-2024, 01:52 PM
gsmith660's Avatar
The first new parts! More on the way the turbo has to go back to turbokraft for repair looking for a box that will work now
Old 01-08-2025, 08:28 AM
gsmith660's Avatar
Most of the parts for the short block are on the way. Using a GT3 oil pump reaming the oil squirters out 10 thousands, the turbo going back to Turbokraft for repairs and some performance upgrades to support the higher output engine getting things set for twin plugging. Will post pics as I get them.
Old 01-10-2025, 10:41 AM
gsmith660's Avatar
The cams, heads, and rockers al going to get machined
Old 01-10-2025, 11:48 AM
gsmith660's Avatar
Goodies are coming in more to come over the next couple weeks
Old 01-14-2025, 12:26 PM
curious; do the arp through bolts call for the same torqye setting as factory?
Always learning.
Old 01-14-2025, 02:48 PM
gsmith660's Avatar
I can look at the instructions and let you know edit: the torque spec is 25 ft/lb I think stock is 35 ft/lb
Old 01-14-2025, 02:52 PM
