jwakil's Avatar
Trying to adjust Fuel Mixture on 930 for elevation
I've moved my 930 from Texas to Colorado and sense it is running a little rich, so was trying to lean it just a hair. What puzzles me is that my adjustment mechanism seems a little different than all the pictures and videos I've seen. I was expecting to have a hole between my fuel distributor and throttle body where you stick the 3mm allen key into. Instead, I have a tube that sticks out as shown in the picture. When I put my allen key in there, I can feel a spring I can push down on, which goes quite a way down. I was also expecting that when I turn the key, it should have distinct clicks. However, when I turn the key I can feel slight resistance but there are no clicks. So I'm not sure if the key is not engaging or I need to push down on the spring. I don't want to turn too much and mess up the mixture totally. Should I be pushing down on the spring, and should I be feeling clicks or not. Why do I have this tube sticking out unlike others?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 02-06-2025, 03:18 PM
908/930's Avatar
I think the tube is normal. It's been a while, push against spring should feel key engage, no click when turning. Only requires small turn to adjust.
Old 02-06-2025, 04:01 PM
mark houghton's Avatar
As already described. Spring loaded adjustment post. Just keep pushing down gently until you feel resistance, at which point when you turn your allen wrench you will feel it engage. If you continue pushing down you'll end up deflecting the metering arm and you'll see the rpms drop due to overly rich condition. Very small turns, just a degree or so at a time
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-06-2025, 05:52 PM
dos531's Avatar
Sounds like its working as its supposed to, but that mainly changes the mixture at idle.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
CIS sucks balls
Old 02-06-2025, 06:19 PM
jwakil's Avatar
yes after further research it seems if I want to adjust mixture at non-idle I need to adjust the WUR. At this point it doesn't run too bad, just feel slightly sluggish and less power (probably because of the thinner air) so reducing fuel wouldn't increase power. So I will leave as is for now. In the summer time when the air becomes even less dense is when I might need to do something.
Old 02-06-2025, 08:09 PM
jwakil's Avatar
My warm up regulator is as shown, which I believe the previous owner made adjustable. I know the screw marked A is for the cold fuel pressure adjustment. I would raise up the screw to lean and go down to richen. How do I adjust the hot fuel pressure? Is that the blue screw mechanism marked B?
Old 02-06-2025, 08:37 PM
Bucketlist's Avatar
If you have the BL Adjustable Wur it will look like this on the bottom and you can carefully snake a 4mm allen wrench under the wur into the hole and adjust. I adjust mine when the car is warm, engine not running and fuel pumps running with battery charger attached while watching fuel control pressure on a gauge. Warm pressure about 3.65 bar or 53 psi warm.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 02-07-2025, 03:34 AM
dos531's Avatar
I have the pdf manual for the adjustable wur if you need it. PM me your email and ill send it to you.
CIS sucks balls
Old 02-07-2025, 12:49 PM
Alan L's Avatar
You should not be fiddling with 'A' unless your WUR is out of whack - ie needs some remedial work.
The mixture adjustment you seek is as shown by Buckelist.
But without proper AFR numbers your are shooting in the dark, going by feel.
Mine does go rich at 3000 ft ASL - it makes a difference.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-09-2025, 07:01 PM
I'm not sure why you would ever need to adjust it for altitude.
The device is a mass flow meter, not a volume meter.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 02-10-2025, 09:34 AM
Alan L's Avatar
Hmm, that makes sense. You wouldn't expect it to be so non- compensating. But my AFrs are richer at 3000 ft. I do tweek the WUR. Have a higher pressure setting. But for normal use it probablyu wouldn't matter. But I am trying to get the last bit out of it.
Alan
Old 02-10-2025, 09:48 AM
Alan L's Avatar
That would suggest the airplate does not fully open at altitude at WOT?
Alan
Old 02-10-2025, 02:14 PM
dos531's Avatar
In theory the afm should compensate for altitude somewhat, but in my experience it does a very poor job. Yet another reason the CIS belongs in the garbage.
CIS sucks balls
Old 02-10-2025, 03:58 PM
66cal912's Avatar
You should hit up Jacob, he's in Colorado too, and running his car in all the high altitude mountains. He has a build thread on here: https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/853761-its-about-time-finally-have-79-930-a.html
or you can DM him on Instagram, https://www.instagram.com/jacob.schramm/.
He's running a later 964 turbo WUR part number: 0438140160 that is able to compensate for altitude better some how, which the original 930 wur struggled with at altitude. I picked one up on Ebay a couple years back but have yet to have it overhauled for my 930. He said it was a huge improvement for the altitude variation he was getting from his original WUR. Its possible he has more details in his detailed car thread.
The base of it is much thicker so it has something else going on inside compared to a normal WUR. there is one here, which you can see has a much larger lower section but the price on this one is a bit nuts..
https://www.fuelinjectionproducts.com/products/porsche-911-reman-warm-up-regulator-bosch-0438140160?srsltid=AfmBOoqxxlHhXzh7TgASQ01dgcj8MWn o8B2iutBJ3l_Eha6f-suESUOL
Ben
'79 930
Instagram / Duhasst930
Old 02-11-2025, 08:35 AM
im curious what is screw B? im guessing a blocked off port that was installed to monitor real time control pressure while the engine is running?
Old 02-11-2025, 11:30 AM
Bucketlist's Avatar
"What is that the blue screw mechanism marked B?"
Maybe it used to look something like this.....
Old 02-12-2025, 03:24 AM
Crotchety Old Bastard
RarlyL8's Avatar
The plug marked "B" in your picture on past #6 does look like an a gauge fitting. It should be removed and the proper fitting put back.
The adjustment customization labeled "A" in your picture is for cold pressure only and is typically an indicator that the WUR is failing. There is no need to change CCP specs on a properly functioning WUR.
930 CIS does not compensate for altitude, that is done using the idle adjustment screw. If your altitude changes significantly, which is not a normal thing, you may need to give it a tweak same as you would for a carburetor.
964Turbo CIS does compensate for altitude. The -160 and -164 WURs have an extra diaphragm that sees atmosphere and deflects accordingly. Using one of these will solve the problem if you live in the mountains and frequently change elevations. The CCP and WCP should be close enough for a plug and play if using a -145 fuel distributor. A tweak of specs would be beneficial if using a -037 or -016 fuel distributor.
Old 02-12-2025, 11:37 AM
Mr. Merk's Avatar
I second this. He and the rest of the Colorado Turbros have wideband AFR gauges in their cars and have this down to a science.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 02-12-2025, 12:25 PM
jwakil's Avatar
Yes, I think screw B was for a gauge. I'll hit up Jacob. I think the car is fine at 5k feet, but some of the mountains here go up to 10k+, and I had a hard time starting the car when I got up there. I'm thinking the idle mixture might be all that I need to adjust but that is counter to several other postings I've read. Another thing I'm thinking of is going with a Zork tube, which I've been thinking of and which would make it run a little leaner by default.
Old 02-24-2025, 10:26 AM
Banned
jkkarrow's Avatar
Looks good
Old 02-26-2025, 06:29 AM
