how to set timing
hi i just got done building my first 930 motor(stroker knife edge crank c2 p/c boattail cases 40 mm intake ports balanced on and on) but how do i set the ignition
timing thanks
bump
if you are talking about the dizzy, just set it statically. To do that, make sure the engine is at TDC (verify by checking cylinder #1). Then point the dizzy rotor to the notch on the dizzy casing (will be a small line that looks like someone took a chisel to the metal casing). This where spark plug #1 will go, then follow firing order listed on the engine bay sticker. Once you start her up, use a timing light to make final adjustments.
If you are talking about cam timing. do a search for my name, and cam timing. We covered it very extensivly in a thread.
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
