Macht Schnell
Mod'd 930's, What size Header primaries?
Hello,
For you folks that have mod'd your 930's. What diameter of Primaries are you using on your headers?
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
E-85 sippin drunk
i am in the process of making my own headers utilizing Burns collectors. I will be going with 1 5/8" primaries. i want to keep the velocity up. I have read that 1 3/4" to 1 7/8" is too big for a 3.3 to 3.6L motors... if anyone else has an opinion.... let it out. I am at the stage of ordering material.... So, still open for changes....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Crotchety Old Bastard
Design to application is crucial. Too big and lose velocity as stated.
Another design issue is primary length and symmetry. This is also critical to efficiency. Very few headers have equal length primaries. What are your goals, specifically? I had a well-know "tuner" tell one of my customers that 1.5" primaries were too small for his 400HP application. I sent him a picture of a 600HP engine using the same exchangers. LOTS of BS out there. Find an unbiased expert who builds successful systems without being tied to the manufacturer giving the best discount. Goran (beepbeep) comes to mind.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Macht Schnell
Hi,
I have some cracks in mine, I believe they are 1 5/8". Since some new ones may be in my future, I was just wondering what diameters most are using.
My car made 5 to the tire on a 12 year-old set of bolt-on B&B's that were modified for a T-4 flange. I dont know, mabye I should go bigger...
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Wo ist die Rennstrecke?
I use 1 5/8 headers on an EFI car. If it were CIS, I would stick with stock. I also have equal length headers, but would recommend short pipes for mostly street driving. The most important part of my pipes is the waste gate circuit and how efficient it is.
Mine are 1 3/4 equal length headers with twin tial 44mm wastegates. This is the most responsive, and best flowing setup for a single turbo car. With a large single turbo the single pipe is not the best design. Granted this setup is overkill for most, but looks killer anyway
Navin Johnson
Bigguns
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Doug Siegel
1 3/4
88' blk/blk 930: Haltech EFI, Twin Plug, Pauter Rods, Nascar Bearings, custom crank work, dowel pinned case, ported manifold and heads, Kokeln I/C, SC Cams, Turbonetics ball bearing 62-1, BB headers, RARLYL8 Zork, additional 993 oil filter, plx/inyourface gage, RS style coilover, Fikse FM10-17 wheels, TIAL 46mm 1 bar. (where the heck did all my money go? )
Expected peak power/torque range of the motor, and overall power output(expectations/goal) really are needed to determine what primary size to use.
In lamens terms......how much power you want to make and where in the rpm band you want to make it most. There are so many variables in the final decision it cannot really be laid out here easily. Example: Eg33 motor going in my 962 kit car-------> 3.3L(96.9mm B/75mm S), GT3582R .78AR twin scroll, sequential meth injection ~500whp 1-3/4 primaries into 3-1 merge collectors into 2" parallel up pipes to turbo volutes(TS flange). Making peak power on this setup around 4600rpm(redline 7200) Realistically on a street car response and torque is what you'd want and a smaller primary(all else equal) is better for that.
Adam Hennessy |
Bigger is definitely not better. 1 3/4" primaries reduce velocity, the function of which is a square of tubing diameter.
Exactly, 100%. This is why 90% of my business in designing and fabricating headers and intake manifolds revolves around very specific setups. IE, I'd build an intake manifold based on a particular engines' comp ratio, rpm range used(or expected gain area), specific camshaft lift and duration, port sizing, etc, etc. Flow vs velocity and reversion characteristics make the job tedious. Same theory applies to header design. In any effect, even a smaller runner header, if designed right, can and will flow very very well up top and not sacrifice low end torque or response.
Adam Hennessy |
