Anyone know if the Clewett scavenge pump/cam sensor will fit a true SC cam or does it require the drive extension of the 930 cam? I am also intrigued by the air pump pulley Hall sensor setup. Anyway to drive the pump pulley off of an SC cam?
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Happiest when Tinkering
How different is the sc cam from the 77 cam I have a tower setup and cam from a sportomatic motor that has the cam setup in the back for the sporto oil pump.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
E-85 sippin drunk
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
E-85 sippin drunk
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
R.I.P.
I would assume just about any aftermarket EFI system could control an EDIS6 and with only a crank sensor needed for operation why spend truck loads of money and pull your hair out? $100 gets you a complete EDIS6 system
Mine works great and I haven't needed any kind of ignition amplifier. |
Wo ist die Rennstrecke?
Don, I would love to see some pics
Drive it like u stole it.
+1
idle quality is enhanced using full sequential injection. Big injectors tent to create a rough idle condition so sequential becomes more important. Sequential is also more consistent among other things.
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Checked out your pics on flickr nice job looking forward to a project like that myself in the future.
I emailed Richard about their combined cam driven scavenge pump and cam sensor and he says that it requires the 930 cam drive boss so it cannot be added to a true SC cam.
Did he say anything about the price or is it still 700+?
I didn't get that far. I have SC cams so there was no point. I would have to convert to 930 cam blank to use his. I already have a Tilton electric pump for scavenge and the Clewett cam sensor on the driver side cam so I will stick with that to avoid huge mods.
Here is a pic of the magnet that that I drilled and tapped while the cam was in the motor.
![]() This is what the adapter looks like with the sensor installed. The space around the sensor is recessed because that's how wide the GM sensor is compared to the Honeywell. ![]() This is just a shot from the side. With the gasket, I set the gap to .040. ![]() This is a shot of the exterior of the cam position sensor. I laid a piece of 5/16 aluminum over the original hole, welded over the hole, then drilled and tapped the hole for the Honeywell. The thread pitch on the sensor is 1 mm so each complete turn is 1 mm. Screw the sensor down until it touches the top of the magnet, then back it off 1/2 turn for .020 or one full turn for .040.
Don- thank you for the pictures- they are very helpful. I am in a last ditch effort to try to figure out the accel distributor/ haltech programing and then I am going to go the way that you did for the cam sensor. Dont know for the crank pulley yet.
Slantnose from HELL
Haltech use to sell a switching trigger that when you set the magnets in the wheel all the magnets would be set in the wheel at north polarity but the magnet at TDC was set at south polarity and he switching sensor would tell the ECU when TDC was rached due to the one magnet being set to south pol. Not sure if this
method is still practiced with the Haltechs or not. Try contacting Mark from Hargett, he is good friends with a Haltech dealer that is one of really up with the latest and greatiest. |
I assume the reasion of all this effort is to go fully sequential instead of batch at the injectors.
If the car has a distributor is seems you should be able to do it there instead of on the cam and it might be easier. SC, you can have a drive mounted on your stock cam for about $200 if you really need it. I had this done many years ago for an MFI conversion. You do not need to start with a 930 blank. |
