Web Cams.
Old 03-01-2010, 05:51 PM
Forced Induction Junkie
WERK I's Avatar
Originally Posted by 911st View Post
....................edited for space.........
SC, you can have a drive mounted on your stock cam for about $200 if you really need it. I had this done many years ago for an MFI conversion. You do not need to start with a 930 blank.
Keith, are you talking about the extension pictured in the red square?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-01-2010, 06:07 PM
That looks like it.
Old 03-01-2010, 06:11 PM
WERK I's Avatar
Its not really needed unless Steve is planning on using the air pump drive. This is discussed earlier in the thread. The camshaft will still need to be modified, tapped, to support mounting of the extension to the cam.
The extension is mentioned in Bruce Anderson's 911 Performance Handbook, Third Edition. Its a Porsche Racing Part Number: 911.105.171.02
Dave
Old 03-01-2010, 06:45 PM
I thought he wanted it for a turbo savaging pump.
Old 03-01-2010, 07:31 PM
sjf911's Avatar
I would need to add it to run the Clewett combined scavenge pump and cam sensor or to retrofit an air pump drive to make my own cam sensor. I would like to convert to a mechanical scavenge pump at some point to get rid of the Tilton. I already have a stock 930 pump set aside but I currently have the Clewett cam sensor installed on my driver side cam am awaiting MS3 for sequential injection.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-01-2010, 07:33 PM
sjf911's Avatar
LOL, still available and only $440 according to PP. I'll have to think of something else.
Sapere aude
Old 03-01-2010, 08:28 PM
WERK I's Avatar
ROTFLMAO!! And I thought $200 was laughable!
Steve,
Why do you think you need the camshaft drive extension?
Dave
Old 03-02-2010, 06:06 AM
I did this years ago and it was about $150. Web Cam I think makes there own and included the extension in the price from what I recall.
The factory piece for an MFI conversion is to expensive to use and may not be the same as the 930 uses for its oil pump.
A lot of guys buy SC or C2 factory cams and have this extension added. Just check with any good Porsche cam grinder and they will probably be able to convert your cam for a reasonable cost.
Old 03-02-2010, 08:41 AM
sjf911's Avatar
Thanks for the info. It is a future project. I will stick with the Tilton for now and await MS3 for sequential injection and direct coil control. After MS3, when circumstances allow, I can consider my options for converting to mechanical scavenge but retaining cam sync.
Sapere aude
Old 03-02-2010, 08:49 AM
OK,
I called Web Cams. Cost is $165 to convert an SC cam to drive a 930 oil pump. No factory spacer needs to be purchased.
Web Cam Inc. - Performance and Racing Camshafts
sjf911's Avatar
Great info, thank you.
Sapere aude
Old 03-02-2010, 09:09 AM
Haltech Speciallist
Send a message via ICQ to HaltechClaudio Send a message via AIM to HaltechClaudio Send a message via MSN to HaltechClaudio Send a message via Yahoo to HaltechClaudio Send a message via Skype™ to HaltechClaudio
Originally Posted by 930gt-40r View Post
So.... I am on the verge of starting to wire up my Haltech that I mentioned a while back and I am now thinking about triggers. Currently I have an Accel dual sync distributor (includes cam and crank...), but am having a hard time figuring out how to configure it within the Haltech and neither Haltech or Accel want to give me a solid answer about how to set it up. So now I need to set up a hall effect crank signal and an hall effect cam trigger. The crank trigger I pretty much got figured out- My real question is:
What are the distributorless guys running for a cam sync/signal? I have already seen the clewett offerings and neither are very viable for me (although they are cool...)
Hello All, i came accross this and honestly wondered about your problems. First let me say that its possible you have probably not called the Haltech US office, if you have, you probably may have not talked to me. I have actually done a few Porsches in my time and i must say i love them to death, especially the old ones.
Having said this, i am here to answer your questions about triggers. The simple answer is that virtually any option is possible, its just a matter of prioritizing your needs. If you want to maintain originality, sticking with the distributor triggers is fine, if you want all out performance, a crank+cam setup is needed. We have single channel and dual channel hall sensors in stock that can let you do just that, we dont sell trigger wheels but we do sell the rare earth magnets that can let you build a custom flying magnet trigger, either inside the distributor (as ive seen some pics on this thread, or on the crank pulley.
Motronic, missing tooth, trigger wheels work very well, especially the 36-1 using a hall effect sensor, this only provides for half cycle, wasted spark/semi sequential, operation, but if you modify your 6 tooth/slot wheel inside the dissy leaving only just one tooth, this can double as your sync/cam sensor with no problems.
Haltechs can read Hall or Reluctor style setups and with the new Platinum ECUs you can properly configure your reluctor triggers to permit perfect triggering all the time using the trigger/home voltage threshold tables, filter levels and proper wiring and configuration of the trigger setup page.
I have never met an engine that could not be run given the appropriate trigger installation.
If you have any questions, please feel free to call me at the US office, just ask for Claudio.
Have a good one boys. I dont know if i will monitor this forum much, but my contact info is bellow.
HaltechClaudio
Haltech USA/Latin America
Tech & Sales
Tel. 760 598 1941
Haltech - Engine Management Systems
Old 03-05-2010, 05:24 AM
930gt-40r's Avatar
Just got off the phone with Claudio^^^^- It looks like I am going to keep the accel distributor as at can work with the computer. It turns out that I was not contacting Haltech direct, I was contacting dealers and they were the ones who didnt want to help me with my problem. Ten minutes on the phone with Claudio took care of all my concerns with the distributor and more. Thank you Claudio!!!
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-05-2010, 10:47 AM
Happiest when Tinkering
gsmith660's Avatar
Bravo I am glad at least one of the companies involved jumped up to the plate.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 03-05-2010, 10:55 AM
R.I.P.
drmatera's Avatar
thats a great resource....
Thanks for coming on here Claudio
Old 03-05-2010, 11:41 AM
Haltech Speciallist
You're all welcomed guys! I can honestly tell you that anything is possible when using these units, pretty much all possible angles can be covered.
Let me give you a quick run down, you can run the stock dissy from an old air cooledmotor, you can use the 60-2 trigger sometimes found on a few more modern years, you can build your own custom setup as ive described in the previous post, you can customize your existing hardware, or add some more.
These cars are loads of fun, power potential from what ive seen is incredible, all it takes is a little information, which we can provide!
Here are the sensors we have, this is the "GT101", its a single channel hall effect sensor that is similar to some bosch units as far as dimensions and installation style.
Here are the rest, from left to right, "Red Hall Sensor", "S4 (dual channel)", "S3 (dual channel)". The S3 and S4 are the ones that use "rare earth magnets".
And of course, Haltechs are perfectly capable of reading of most reluctor style sensors. All it takes is a little patience and the right settings.
Old 03-05-2010, 02:53 PM
gsmith660's Avatar
Hope you got permission to sell your wares though, Wayne is a little particular about that.
Old 03-05-2010, 03:10 PM
Seems to be a problem as of late. Everyone with a buisness license are becomming dealers now but don't know jack **** about providing 'support' for the product. Anyway I contacted Claudio after stumbling on this thread so you're in good hands now.
Another option for you would be to just use the ACCel distributor for the cam/sync and use a Clewett crank trigger kit.
With the above setup you got many combinations available for both ignition and injection setup. You can run full sequential injection with a direct fire coil on plug or a wasted spark setup.
Clewett Engineering Catalog: Crank Trigger Adapter Kits
MIKE AWD's EVO8's GSR 8.75@167mph/RS 8.98@156mph E85
CHARLES/RAW 2JZ S2000 7.77@187mph E98
SFT MKIV SUPRA 7.84@179mph Vp Import
BIG DADDY PERFORMANCE SUPRA 7.60@186mph E98
Old 03-05-2010, 03:13 PM
So for a Carrera conversion we can use the Motronics Flywheel sensor and can we put something in the stock EFI dist to indicate motor/cam phasing?
Old 03-05-2010, 03:15 PM
