Basically yes.
MIKE AWD's EVO8's GSR 8.75@167mph/RS 8.98@156mph E85 CHARLES/RAW 2JZ S2000 7.77@187mph E98 SFT MKIV SUPRA 7.84@179mph Vp Import BIG DADDY PERFORMANCE SUPRA 7.60@186mph E98 |
Happiest when Tinkering
Sorry that sounded alot more harsh than I meant it to but that so sounded like a sales pitch. Glad you are now getting tech support.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Haltech Speciallist
60-2 +1, 36-1 + 1, are considered "motronic triggers", or missing tooth triggers, using a cam ref. Any even number of teeth on the crank over 6, 12, 18, 24, would be a multitooth setup, and would require a single pulse on the cam. Then we have the "standard triggers", even number of teeth (equal to the half the # of cylinders) on the crank + 1 on the cam. This would be Standard Trigger Full Cycle, providing info to run sequential/direct fire. Then you have the "half cycle" which would be something like an S3 or S4 with flying magnets on the crank, and the last is the "no home", this would be the OEM distributor with same number of teeth as you have cylinders. |
Haltech Speciallist
Hope it didnt sound like i was selling. |
Sorry again you definately know your stuff about this hope you stick around to add insight to those who need help.
Haltech Speciallist
No problem! If anybody wants to start a Haltech tech/tips/troublshooting thread by all means go right ahead and PM me when you do.
yep, im slow in the head
good info
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something |
Macht Schnell
Hi,
Don't know if this will help or not. It's been a while since I did this and my memory ain't what it used to be! On the back of my Scavenger pump on the Driver's side CAM there is the pulley for the air pump. I drilled and tapped that for a bolt. RED loktited a bolt in there at the proper point for timing. I drilled the housing around it for the cam sensor and set the gap and that was how I solved this conundrum. I skimmed the thread, hope that was the question at hand? I took a zillion pix but didn't document this for some strange reason...
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Macht Schnell
Hi, thanx!
No plans of a build thread. It seems like you're never done! Always something else to do for some reason.
You got that right I started a build thread and got slammed by someone that I didn't expect cause it was taking to long, it really does seem like there is something always next.
I still have ECU wires hanging loose through out the car for things like wheel sensors, different map, different boost settings, nitrous , hidden kill switch and various other things.I've been just happy that almost everything works that I've moved on to other projects.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Subscribed!
Going M600 & 3.2 Manifold soon, have the M600, just need to make the harness, any thoughts? Thanks, Dave
Thanks, Dave 3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
I spent about $1200 in material to build the harness for my M600. I checked, double checked, and triple checked and I still made a couple of mistakes. I could have saved myself a lot of heart burn by shelling out the extra money for them to build it. I put a bulk head connector at the fire wall to make pulling the engine easier. Even though I used very good DT gold plated connectors, I wonder if it doesn't add unnecessary risk for a bad connection.
Macht Schnell
Nice Job! But that's not the Harness he's talking about. The EFI Harness does not exist on a 930 to cleanup. 930's don't have EFI.
Turbonut
Sorry, can't imagine too what on earth would make a harness cost 1200$. Did you use mil-spec connectors or something?
I make harnesses all the time (I install and tune EFI systems, specifically VEMS) and make harnesses out of silicone insulated wires, all new JPT connectors etc and it barely costs 200 in materials. But regarding trigger setups. If you are going for the hassle and install crank trigger, why on earth would you want to install magnets? Use better sensor that don't need magnets, for example, Honeywell 1GT101 that is Hall sensor and requires nothing more than a bolt head or other metal tooth. Makes your life so much easier. And I recommend multitooth trigger over "simple trigger" because multitooth is much more precise. It works without cam sync also, you just won't get sequential injection with out it. You can go semi-sequential, meaning firing injectors one-by-one, but they are not timed. It is usually wiser to choose engine management based on how many sensors you won't have to swap on the engine and what it can do, instead of being forced to run certain sensors. Best choice for 911 (at least with 9bolt cranks) is to use 964 flywheel that has 60-2 trigger arrangement, next to that is laser- or water-cut trigger wheels mounted to crank pulley (36-1, 60-2). It costs around 30$ to have it cut and find some VR sensor from ANY car that has it stock, you have a hard time spending over 100$ for crank trigger setup (that includes centering the trigger wheel to pulley by machinist).
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
I understand what harness he's talking about and I am just using a much bigger project as an example since I agree with raceboy I cant see how a smaller harness can cost that much even if you include trigger wheels and such.
On the other hand, I did build this engine harness for a little over $100 which gets rid of all the stuff that the EFI handles:
I would still like to see pics it looks like you do fantastic work. I understand wanting wiring that will last, but that wire you used will still be looking new long after the car has gone back to dust.
