David's Avatar
Here's the latest pic I have (it's not as pretty with wires and hoses everywhere ):
Here's how I laid out the M600 wiring although I don't have about 1/4 of the stuff actually wired like the wheel sensors and cockpit switches:
Old 08-30-2010, 04:43 AM
Happiest when Tinkering
gsmith660's Avatar
Looks very nice. Did you make your own billet brackets?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-30-2010, 05:00 AM
Turbonut
Raceboy's Avatar
The silicone insulated wires that I used don't crack with heat & cold cycles and I have the harness made from it in my turbocharged 924 for 4 years, no hardening of the wires, nothing. Withstands contact with exhaust without melting etc.
There is always numerous ways of doing things but 1200 for harness materials is clearly overkill for a hobby racecar. There is just no point in claiming the most expensive way is the only way. Question is: what is the goal? And follow the requirements to achieve it, be it with your wallet or your brain (or both).
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 08-30-2010, 05:24 AM
David's Avatar
Yes. I'm not a machinist (well maybe an amateur machinist), but I work in a machine shop so I have access to the machines.
Old 08-30-2010, 05:41 AM
drb930's Avatar
Originally Posted by David View Post
If you're really good at wiring you could do it yourself. I'm above average at wiring, I built the harness myself, and I wish I paid Motec to build it.
I spent about $1200 in material to build the harness for my M600. I checked, double checked, and triple checked and I still made a couple of mistakes. I could have saved myself a lot of heart burn by shelling out the extra money for them to build it.
I put a bulk head connector at the fire wall to make pulling the engine easier. Even though I used very good DT gold plated connectors, I wonder if it doesn't add unnecessary risk for a bad connection.
I have a lot of aviation avionics installs, do you think that will qualify?
Thanks for the input,
Dave
Thanks,
Dave
3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
Old 08-30-2010, 06:11 AM
David's Avatar
Dave
You'll probably do much better than I did
My biggest issue was ground wire connections in the harness. I crimped them together using standard unisulated butt connectors and heat shrunk them. For some reason I got a few bad readings when checking the harness and had to open it back up and fiddle with the connections. I don't know what I would do different, but hopefully a good wiring guy would do better.
If I did it again I would use better heat shrink tubing. I used pretty good stuff, but I'd spring for Aero quality stuff next time. Especially since there are good Tee's and other shape shrink tubing from Aero suppliers.
I was glad I used good DTM connectors even though they're more expensive and require a $300 crimping tool, they are a much more positive connection than Weatherpack or others.
Old 08-30-2010, 08:32 AM
Navin Johnson
TimT's Avatar
I use "expandable mesh sleeving" for the bulk of the harnesses I make, only using heat shrink at the terminus of each circuit...
Sleeving
And Weatherpac connectors.. mil spec connectors are cool.. and better than the Weatherpac if a customer wants mil spec thats what we build... If he want to get a harness that works just as well and costs much less than the mil spec... Weatherpac..
I can't find pics of the whole harness I built for my car, but here is the expandable sleeving, and the bulkhead connector
'69 911 GT-5
'75 914 GT-3
and others
Old 08-30-2010, 03:22 PM
930gt-40r's Avatar
Tim- you use Ballenger Motorsport?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 08-30-2010, 03:31 PM
Navin Johnson
TimT's Avatar
We probably buy from the people that supply Ballenger
Had not seen that site before
'69 911 GT-5
'75 914 GT-3
and others
Old 08-30-2010, 03:43 PM
