air filter replacement
pretty basic question but if there is a trick i don't know about... i want to replace the air filter in the stock air box. do i need to loosen / slide the a/c compressor out of the way to get the clearance needed once the bottom of the air box is cracked open?
Charles 88 911 Cab 74 TR6 88 CRX Si 79 930 #632 (sold her and survived her) |
After the next project
Answer
I have an A/C equipped 87-930 and have always been able to just crack the air box on the front, open it up as much as possible (an inch or slightly more) and slide the air filter out bending it slightly to get it past the A/C unit. I have never had to mess with the A/C for the air filter. I do have a K&N air filter... not sure if that would make a difference. It doesn't seem like it would.
Hope this helps, Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
E-85 sippin drunk
Also I have a K&N air filter for sale that has never been used for a 930... if you are interested....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Stock or K&N, you have to work at getting it in. A little KY would help.
J/K.... |
Driver
Having just replaced the air filter on my stock engined car last month, no, nothing has to be disassembled. Flip the three snaps, slide the old one out, slip the new one in, lock the snaps.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I usually just use this time to remove the Intercooler and AC pump. The box is much easier to get at and you can inspect and clean items which normally are impossible to get to. 15-20 min of removing items allows for much better access and a lower possibility to loosing or breaking something.
JMHO
Michael PCA-INWR 356 Reg. Early S Reg. R Gruppe PNW |
