twin plugged targa's Avatar
removing #1 and 6 spark plugs?
Can anyone advise best way to access and remove #1 and 6 cylinder spark plugs-
under the distributor and at the back right side - under air filter
Do I have to remove the IC and the air filter casing/assembly?
- For the IC is it just a matter of removing hose clamps and then pulling up to release the O rings?
- for the air filter assembly or filter 'end piece'(?) I undid the 2 visible clips in view but it seems to be hinged? are there clips at the rear or some other reason it will not come off?
Many thanks
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 01-18-2011, 05:08 AM
totle's Avatar
Hi Ben,
IC is connected with 2 bolts rear (under IC from rear), 1 bolt on front left side and 1 bolt front right side. All 13mm bolts. Then just pull up to release O-rings.
Air filter is connected with 2 10mm bolts on top of the air filer and with 1 13mm bolt under, right above WUR. Also there is a hose connected in the rear for oil breather.
I also remove the 90 degrees rubber connection for the downpipe to easy reach cyl 1-3
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-18-2011, 07:01 AM
Thanks very much for the help- does'nt sound so difficult now!
I will attack the last plugs this weekend!
cheers
Ben
Old 01-18-2011, 11:19 AM
