Which MSD to get for my 89 930?
Any advice? I want (need) to replace my Permatune and want a simple bolt on MSD.
From what I've read, I seem not to need a tachometer adapter but am not sure. Here on Pelican a MSD 6200 is listed but everybody seems to recommend a 6 AL. Are they the same? I'm a bit confused as to what to get. Also do I need a rev limiter? My car is a simple daily driver (almost). |
The 6AL has a built in rev limiter. That's what I would use as a minimum, but others are using one that can control timing with boost iirc.
Registered Driver
There is a new 6AL-2 which is smaller and easier to fit. It is also available in a fully programmable or manual setting model.
Ben '85 930 - Black on Black '95 993 Turbo - Silver |
Do I need anything else with this AL2 (tachometer adapter, rev limiter, ...) ? Is it best to order it directly from MSD?
Should I also get the MSD Blaster SS Coil Part No. 8207 ?
I would also change coil when going for a MSD.
If you want to place the coil where the stock is, I would go for 8222. I tried 8202 on mine, but it started to leak oil since it was not vertical mounted. The result with low oil level in the coil was cut of ignition in left turns :-(
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
With the 6 AL2, MSD recommends the 8207 although they say that it works with almost any coil.
Funny you say that... I noticed mine leaking slowly - had upside down for many years. R u sure the coil did that making left hand turns??? My car did the same thing(now& then) Always wondered why it did that. Walt |
Yes, 100% sure it was the coil. I scratch my head and checked all other stuff first, but when I had the coil out to switch it with the stock, I noticed the leak of oil, had made the kernel inside to slide up and down inside when shaking. Probably leading to shortcut, when turning hard.
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo Last edited by totle; 01-14-2011 at 06:34 AM.. |
JEESSSSUS.....
I've been more than scractching my head....Trying to keep my HEAD ON... ![]() Did it make a mess or just being wet around that area??? Did u chk the ohms? Walt |
Mine was mounted in the original bracket, but had it places with wires upwards. Did not make too much mess since it was not leaking much. But enough to make it shortcut.
Never ohm'ed it. Just replaced it witch a new MSD coil. 8222 does not have oil kernal, but epoxy filled.
Trond-
Exactly!!- Same thing as mine.... Will change it--Gotta open the wallet again,,,,,,,,,.. ![]() Walt |
I was running the 6AL on my 911 using the blaster high vibration coil (mounted in the original position upside down is ok on the high vibration coil)and it was running great. Isn't the rev limiter in the tach on these later cars? not sure... I was not using the tach adaptor and it was ok.
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
Guys,
Might be able to help a little here. For a direct replacement for you present ignition system use a MSD 6AL-2. Great ignition and virtually bulletproof. No programming capability just plug and play. If your going to play, I went with the MSD 6530 Programmable. I'm using it because I want the flexability of programming my timing curve and also backing off timing under boost by programming boost retard. Both these units will require installing the MSD 8920 Tac Adapter and a MSD coil. I would use the MSD 8207 Coil. Make sure you seat all the plug wire and coil wire completely and correctly. Doing the install you can disconnect the engine harness connector that plugs into your original CD ignition and use insulated male spade connectors to interface the MSD wiring into that connector. In most instances you will have a rev limiting rotor in your distributor. You will need to replace that rotor with a non rev limiting rotor or you will burn out the rev limit feature and be walking home. Porsche standard replacement rotor Bosch Pn 04038: ![]() NAPA alternative rotot (half the price): ![]() MSD 6530 mounted on the bulkhead in the back seat behind the driver seat: ![]() ![]() I added a terminal block where the old CD was to wire in the MSD: ![]() I pulled a switch loop up to the dash and mounted a switch to use as a theft deterent ![]() If I can be of any help just give me a call or a PM. 260-925-0219 Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 01-15-2011 at 12:49 PM.. |
Thanks Cole for your help. If I understand correctly, the Porsche standard replacement rotor Bosch Pn 04038 is a non rev limiting rotor, right?
930 Cab:
I think that is actually the Bosch part number, I have always used the NAPA part, works fine. You should be able to find the Porsche part number here with our hoste. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Is that an old DynaTune gauge I see, which gives millivolt output from your O2 sensor? Precurser to todays AFR gauges. Or some other secret Cole weapon?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
AHHH !!!! Wise eye Grasshopper !!!!
You can borrow the car anytine. Yes it's a Dyna Tune, I use it as a realtime afr display tied into the LM-1 Cole
You can borrow the car anytine. Yes it's a Dyna Tune, I use it as a realtime afr dislay tied into the LM-1 Cole
