Forced Induction Junkie
WERK I's Avatar
Originally Posted by Cayman S View Post
You can contact Marc Noack at marc.noack@porsche.de.....He works at Porsche in Stuttgart. I recently went through this when I purchased a 1987 930S Slant....it indeed was a factory car. My car is a Sunderwunsch...or special wishes and it does not have the 505 designation on the sticker...so that does not mean that just because your car does not have the 505 option code that it is not a factory car. A few features to look for are boxed rockers, one headlight motor, additional oil cooler under the front valance (usually found only on Euro cars), the vanes in the inlet behind the door are made of wood....hope this helps....DR
The strakes behind the doors ARE NOT made of wood. They are composite plastic, held in place by two stainless screws on one side and locating pins on the opposite side of the strake. I don't know how this "wood" thing got its start, but at best its urban myth and at worst total misinformation. You read it everywhere and we've got to stop propagating this. Cayman S, I'm not singling you out on this, it's everywhere, but calling attention to information that may sway people from an actual slantnose vehicle.
The early prototypes may have had wood strakes, but the Sunderwunsch or M505/506's did not.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-22-2011, 07:00 AM
MrShades's Avatar
WERK I I have always read that those ribs where made of wood
But you can tell a turbo from a non turbo on the VIN
Email the person at Porsche because he for sure will tell you if the car is a Sonderwunsch program car
Old 10-22-2011, 01:29 PM
I've gone native
Tt surgeon's Avatar
Mine is a real deal, the slats appear to be a composite materiel. Without actually taking it apart I can't say 100%.
Old 10-22-2011, 01:33 PM
DSPTurtle's Avatar
I love watching you guys fight. It's awesome. How bout one of you takes off their vents and drills a hole to see if you get wood shavings or composite bits.
Composite... hahahaha. Maybe on those cars that had the machine stamped front fenders. But the original 930S has wood slats and hand formed fenders (or do you want to argue that too). I have personally taken mine off and checked. But then again... who the F am I... just a guy that has personally taken them off and checked.
Hey Ralph... please set these guys straight!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 10-22-2011, 06:15 PM
WERK I's Avatar
DSPTurtle,
Do you think I haven't taken mine off to check? I have and refinished them. No wood shavings. Plastic. Do you think that maybe, just maybe, the sunderwunsch product evolved over time?
Handformed, a.k.a.welded front fenders, were done early before Porsche realized its more cost effective to stamp them instead of welding. Do remember 930 rear flairs were handformed before Porsche stamped the turbo bodies in '86?
Dave
Old 10-22-2011, 06:47 PM
kilodawg's Avatar
Hey, my sample size is very limited but one thing that I've encountered regularly is that there are no absolutes when it comes to these cars.
The slats on my '88 are definitely not made from a uniform material like a metal or molded plastic but are made from some sort of "pressed" or "fibrous" material. Whether that's wood based or some synthetic plastic I am not sure. So short of destroying mine I can't say for sure on the M505 cars. I'll have to ask my source at the factory.
Probably should have done that a while ago anyway....I would guess that both answers were correct at different points in time.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
DP935 member
kycarguy 935's Avatar
I have some damaged rear brake veins from a factory M505 and they are like a foam core. They are not wood. I think the wood was used on the earliest models until around 84 or 85.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 10-22-2011, 07:08 PM
DSPTurtle's Avatar
Thanks Ralph. It will be good to know.
Hey Werk1, when did you get your car? Your center console (from the pic in your "garage") doesn't appear to be of the standard fare that the special wishes program put in these cars. Did you backdate it?
I know that the slats on my '85 are wood... I had to repair a chip from a rock or something on the leading edge of one of my slats.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 10-22-2011, 07:12 PM
From my experience the wood ones look smooth like shaped wood would, the others just look like fake wood.
Anthony @ Voitureltd Bayside WI.
Old 10-22-2011, 07:48 PM
WERK I's Avatar
DSPTurtle.
On the Special Wishes options list. there were interior upgrades available that the PO opted not to get.
Dave
Old 10-22-2011, 07:50 PM
I've gone native
Tt surgeon's Avatar
Correction: WOOD
Took a close look, most definitely wood.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 10-23-2011, 03:36 PM
