$38,881 in 2001 is light by today's standards, especially with the G50 included. Be thankful you did not have to bear the cost yourself.
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Spent some time this weekend working on the car- fixed the loose steering column, updated guages with LEDs, cleaned up the trunk, installed new carpet, degreased the whole underside, changed the oil, changed brake lines and brake fluid, cleaned up the wheels and learned they are WORK Equip (12" rears), and lowered the front to match the rear stance.
A few pics: ![]() ![]() ![]() I did try to find out what turbo was installed on the car, but the only plaque I could find on it read OJ27-3. ![]() Still have a list of tasks to complete before Spring which include a sunroof seal replacement, re-install windshield, new seats and harnesses, harness bar, and a few cosmetic interior updates. |
Love the car, the chrome... not so much. Well done on the cleanup, the paint looks really good.
Since these are brand new 315/30s on the rear, I may run these wheels until it's time for new shoes. Hopefully in that time I can have the replacement wheels sourced and waiting. |
registered user
That's a really nice 930 with a bunch or excellent engine mods. And I really like how clean the engine and underside look. Lincoln is right, $38,000 for all those engine/transmission goodies is the buy of the (new) century. Get a detailer who really knows what he'd doing and that already nice paint will be spectacular.
Engine undeside wasn't all that clean until we went through it. Everything was brown until it got cleaned up; even the suspension components revealed color. $38k in mods is a deal considering I paid less than that for the whole car- it really was the buy of the century which is why I'm going through it trying to fix the little details that were neglected. Less than 5k miles since 2001 when most of the work was done, and an amazingly fast car.
Can you tell me where and what kind of LEDs that you put in your gauges? I really want to do that for my 930S. Could you also describe the process? Thanks
Banned
http://forums.pelicanparts.com/porsche-911-technical-forum/644374-ultimate-led-ba7s-bulbs-gauges-ala-etarga-pic-vid.html |
Process SHOULD have been simple- pull the gauges, pull the bulb holder (slip fit into the gauge), swap with LED bulb (twist out), and put them back. However, my gauges were glued in and I never was able to get the tach out so I had to change the bulbs from behind while it was still mounted. Also, I have a NHS boost gauge replacing the clock, and that uses a larger wedge-type bulb which I'm still trying to find a solution for. I have a few bulbs inbound to sees if any of them will work right and match the rest of the gauges. Difference is night / day over the old lighting; looks 100x better. I might still be able to post a comparison if people are interested as I have the old bulb in the boost gauge. Lighting is not only brighter, but much cooler (color temperature) so especially with my silver faced gauges it looks perfect. Set includes blue and green highbeam/lights-on LED bulbs in addition to the lighting bulbs, but there will be other bulbs in the gauges that do not get replaced (mostly red warning lights from what I saw). I have not bothered to look into replacing those simply because improving lighting was my main goal. While you're doing that, I also replaced the trunk lights front and rear and the interior dome lights with LED equivalents. They run much cooler and use less power, and if you wanted they have color options. I ordered these from superbrightleds.com Last edited by EA930; 03-10-2012 at 07:52 PM.. |
Fixed the sunroof, changed the steering wheel, finished the guage LED conversion, gauge bezels, cleaned up the engine bay some more, put the windshield back in. Seats ordered and when they come in, next weekend they'll go in along with the harness bar. Still have to order pedals and harnesses before interior is done. A couple of pics showing before and after, as well as with the lit LEDs (although in lit shop they don't show up very well). LEDs are a cool white, and wedge bulb for NHS boost gauge matched 100%.
