Banned
smaller intercooler
HI
I am putting a 930 engine to my 1973 911E. Does any one know where I can find a small intercooler to fit into original lid or fit into duck tail? need you guys input many thanks!! ![]() ![]() ![]() ![]()
I would rather be driving
I have heard rumor that the stock IC will fit under a ducktail if the outer flange is removed for clearance. Probably just hearsay.
There is a thread about custom ICs to clear a stock decklids. It has been done before.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/561608-anyone-fit-intercooler-under-ducktail.html
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/460855-no-wing-intercooler.html
Crotchety Old Bastard
I built a muffler for a 930 turned RSR clone that had the OEM intercooler under a duck. I'll find a picture for you. It was simple looking, just removed the rubber gasket and trimmed the duck.
Thanks Brian,
I have heard of it but not seen a picture. I was trying to figure out if the trailing edge of the IC would interfere with the grill as the angles are quite a bit different. The ones I have seen had the grill repositioned at a different, more horizontal, flat angle.
There was one really sweet turbo with a duck on the board some years back.
It looked great.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Chain fence eating turbo
So is a full bay out of the question to fit under a duck?
Uncertifiable!!!
It can be done and I'm curently just completing such a project. I'll be posting more updates soon.
http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Stock 3.3 intercooler will fit under some duck tails if you trim the seal around the body. Here is the polished one in my '73 RS look.[img]
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
Brooke, Thank you for posting pictures. Great car. Is this recently for sale?
How much clearance is there between the ducktail on the trailing edge of the IC? It looks like it might be tight. I am wondering if a thicker core would fit under there. Cory, there is certainly room for a full bay as long as the angle and height are about the same. Now I am wondering if a 965 IC would clear.
Jamie,
The car is new to me. It was listed for sale here on Pelican about a month ago. There is almost zero clearance between the trailing edge of the intercooler and the fiberglass of the ducktail. There is no room for a taller intercooler. The only way to use a thicker core would be to have it sit lower. I don't know if that is possible or not (I'm new to the turbo motors and still on the steep part of the learning curve). I do know you can fit a full bay custom intercooler under a duck tail though. Turbokraft and others have done this.
Chris at Turbokraft has done it. I thought there were some pics posted on PP. Sorry, not sure what the thread name was.
Wow a 930 motor in a light long hood? What are you going to do for traction? Are flares in the future? What are you using for a tranny? You have jpnovak's attention...and mine.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
I've had the car exactly one week at this time. It is actually an '81 SC backdated to look like a longhood (glass bumpers, hood, and fender extensions). The paint and body work are all relatively fresh (only 5k miles) and looking very nice so they won't be messed with.
I have not really even wrung it out yet due to my schedule and the lower octane here in WA compared to 93 available where it was in PA. The car is running 8.5:1 compression and I'm a little concerned about detonation, so I am taking it a little easy until I get some higher octane in it. Than I want to confirm A/F ratios and boost settings. Supposed to be .8 bar spring in it now, which is running the ragged edge with the higher compression. It also has 964 cams, which lowers the dynamic compression a bit. Motor has 5k miles on it and runs very strong. I think it should be making between 300 and 350 HP at the crank. Very good off boost performance as well. The tranny is a fresh build of a short bellhousing 930 4 speed. If I find I need more traction I'll stick some 245's on it.
Banned
Here is my one
Thanks you guys input, here is my one. I still need to do some works!
Banned
Hi rswannabe
Can you take some picture of your exhaust pipe? the original is too large, I can not fit in. Many thanks! |
looks good.
Looks like there might even be clearance for an AC rear condenser.
I like it. That car will be a blast once running.
Are you referring to the muffler? I'm running a Monty dual out, so it is not the stock muffler. If you are not referring the the muffler, let me know what it is you want a picture of.
Banned
Here is the exhaust and muffler on my car. The Monty dual out fits with only a very slight amount of trimming of the rear bumper.
Note the car is running the original early US Y pipe headers with the thermal reactors removed. A Euro style header setup is on the short list of changes to make to the car. ![]()
