Help me prioritize please :)
I can`t decide in which order to prioritize my future mods. I`m not sure yet if i need to reseal the engine this winter because of leaks. Bought 15 liters Valvoline VR1 20w50 to replace the 5w50 mobil 1 to try first. Apart from the leaking and a slight valve tick around 6th cylinder, it runs like madness. I actually think it tries to kill me
I got:
k27 7006 turbo
B&B ic
triflow headers and exhaust
XDi ignition
0.8 wastegate spring
Here`s my mods list. I just can`t decide in which order to buy them. I`m not made of money so i need to do it one by one:
Innovative LC-1 Wideband Controller
Momo tuner or champion steering wheel
Tial 46mm wastegate
H4 headlight upgrade
Interior fixing doorcards, sunvisors and back seat refresh
Upgrade the suspension bushes and shocks
Body mods like 930s front mirrors and a gt2 wing
Wheels
The list is sorted by price. If i want say, wheels, i need to save for a little while. Whatcha think? Other mods to consider?
Old 07-18-2013, 02:20 PM
Garage Queen
PorscheGAL's Avatar
Oheggem,
Sticking to your list, I would do the mods in this order. I would add an adjustable WUR after the LC-1. Once you see your AFR, you may need to adjust it. Also, the Tial wastage may not be necessary if your current wastegate is OK and your happy with your spring. Honestly, the OEM wastegate is solid. A change is wheel size will help control the car once you tune with your LC-1
I would move the interior changes up the list, if it means you are removing weight, especially if you are removing the backseat and heavy insulation. Weight reduction is one serious Mod to consider!
Tial 46mm wastegate
Wheels
Just my thoughts. Many on this forum are far wiser than me.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 07-18-2013, 03:56 PM
jsveb's Avatar
Since you say it is trying to kill you the way things are now, I'd do the following:
1. Lc-1 ( to make sure the engine last,while getting good performance)
2. Suspension ( this will make you go even faster, safer -well sort of)
3. H4 now you can go fast at night as well. Important in northern Norway
4. Fix door card and sunvisors. It looks like crap in an otherwise cool car. Low sun dictates use of sunvisors.
I'd skip the rest unless you have some real cool wheels in mind.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-18-2013, 07:22 PM
totle's Avatar
Would do as mentioned.
Drop the wastegate, control afr, if all is good then you can go for a 1bar spring.
If resealing next winter (or in future) put in SC cams :-)
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-19-2013, 11:19 PM
Sound advice there. I get the impression that the oem wastegate is da **** so i`ll stick with it. What happens with the one bar spring thoug? More top end boost or will it boost harder at regular rpms?
Old 07-20-2013, 03:37 AM
totle's Avatar
More top end boost. It will definately pull harder.
Advisable to go with a more efficient intercooler as well, at least in warmer climates.
In Norway thought we not often have that warm climate though:-)
Trond R.
1986 944 Turbo
Old 07-20-2013, 10:19 AM
Is the B&B ic not good enough? Heat is not such a problem here indeed
Old 07-20-2013, 04:11 PM
totle's Avatar
Yes, B&B good enough for your mods :-)
Where are you located? I live in Arendal.
Trond R.
1986 944 Turbo
Old 07-23-2013, 02:57 PM
Good to know cause i just got it Doing the oilchange this weekend so homefully i the valves will shut it and the leaks stop. Crossing fingers.
I`m in beautiful Ålesund.
Btw, mentioned heat did we? Not complaining now
Old 07-23-2013, 03:32 PM
