Turbofrog
Has anyone run turbo with an early rear bumper?
Looks like it might be too tight to fit a turbo behind it ? I like the minimalistic look of the early bumper.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 08-26-2013 at 07:30 AM.. |
Remember there was a pelicanite that posted a picture of a pre-74 with a 930 engine fitted under the ducktale .
Did a search and there is some picture in this thread. http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/475359-ducktail-930-a.html
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Turbofrog
I already have a flat lid and a ducktail and both fit but how about the bumper?
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 08-26-2013 at 07:23 AM.. |
Yes, they're are a couple of those around.. however, fitment on every car is going to be a little different.
Of course you do know; - You will need to remove your reflector box from the tub to fit up the early style bumper. - Your best bet for a bumper source is going to be MA Shaw or GT-Racing
RGruppe #180 So many cars.. so little time!! |
Turbofrog
I think I would also have to run zork or something very small on exhaust side. Maybe too much work and a bit unreversible regarding the reflector base.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
Its reversible if taken out properly, but its work to do so, and more work to properly put back and re-finish.
It fits but is a bit exposed. I think it looks mean with the exposed headers, reminds me of the 2.1 turbo RSR. I have RarlyL8 headers and muffler with custom wastegate dump and tail pipe.
Turbofrog
Nice, do you have bolt on reflector base or is it welded? Any pics of it?
Here's mine with a Monty dual out muffler.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
trans
John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Turbofrog
Reflector box onboost was refering to.
His is a true early car, so it never came with a "Porsche" reflector panel. To fit an early car rear bumper, you'd need to remove the sheetmetal piece between your tail lights.
Have you ever considered using an IROC rear bumper? Would bolt up with no modification, you loose the clumsy rubber bits from the impact bumper too. |
Turbofrog
Yes, it can be done but there is very little room for anything that does a really good job muffling.
Don't put an IROC bumper on a longhood or vice-versa, that is model year mixing and doesn't match well with the rockers and front bumper. Last edited by copbait73; 08-27-2013 at 10:51 AM.. |
Turbofrog
Yeah, you might be right about the over all look with mixed parts.
Smurfbus,
Is there a thread about your intercooler setup you can point me to? I would like to go without a tail on my car, but would prefer to keep an intercooler.
Turbofrog
No thread but Chris at Turbokraft said it was an one off and NOT something they will recommend performance vise as its so thin to fit under the plain lid. But its fine for me and if I see performance loss I will connect again my water meth. I just tried 1 to 1.1bar and all went well and logs were a bit on the rich side so I will iterate until its fine in all gears and rpms.
The last change I made dipped the torque peak area under 11AFR to 10.3AFR so its a bit harsh adjustment but I hope to get a good compromise. Here is the pic from the last owner.
