totle's Avatar
My front bumper re-design
I have been struggeling to keep my engine cool enough on track events.
Before installing a front center mount oil cooler, I thought I could try move my 2 fender mounted coolers in better position, and also open up for more airflow.
I bought a used front fender, that also will provide more downforce, as a core.
I have been inspired of the open ducting that the 993 GT2 evo front fender has.
This is my starting point
Then I started to cut out opening :-)
Then I started to section out the openings...
Then a little trial fit...
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-20-2014, 04:49 PM
totle's Avatar
Design comes along as I go :-)
Found out that the small ducting could be used for cooling duct for the brakes.
Needed something square'ish to round tubes.
Used some plastic soda bottles, cut then in half and used the top section.
Stuck then on a 2/4, to create a mold.
An old rear shock, was used as a mold for the round tube :-)
Then some more cutting and trial fitting.
Brake air duct completed
Finally getting closer to where I want to be...
Trond R.
1986 944 Turbo
Old 07-20-2014, 04:58 PM
jsveb's Avatar
And you even used a norwegian Solo bottle.
Awesome effort! I like it.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-20-2014, 05:09 PM
totle's Avatar
Hehe Jesper, you got that detail :-).
Trond R.
1986 944 Turbo
Old 07-20-2014, 05:17 PM
Mr. C
SAY - 642's Avatar
That looks terrific, Trond.
" Mr.C "
Six = Sex
Old 07-20-2014, 05:27 PM
totle's Avatar
Thanks . Just nice to give some personal touch to it
Trond R.
1986 944 Turbo
Old 07-21-2014, 03:33 AM
Azzurro
Wow that is great work! Looks very good.
Old 07-21-2014, 04:45 AM
Banned
pretty slick there Trond
wish I had your fiberglass skills (or any others for that matter!) - I've still got to figure out a way to mount my brake duct hoses to the back of my rectangular AIR valance
looking forward to your finished product - keep up the good work
Old 07-21-2014, 05:43 AM
I like that, should look great also, keep the pic's coming
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 07-21-2014, 03:15 PM
totle's Avatar
Thanks guys. I will see if I can do some sanding and filler tomorrow.
But the weather is sooooo nice here by the coast in the south of Norway, so spend much time out in the boat or in the sea :-)
Will keep pictures coming :-)
Trond R.
1986 944 Turbo
Old 07-21-2014, 04:06 PM
totle's Avatar
One more round of spray filler, and I think it will be ready for paint.
Trond R.
1986 944 Turbo
Old 07-28-2014, 03:49 PM
MikeD930's Avatar
Nice work there Trond! I suppose you're too stubborn to go with center oil cooler as most others suggested?!? To be honest I'd be surprised if you still have overheating problems with your mod'd front bumper.
MikeD '87 930
Old 07-28-2014, 04:50 PM
totle's Avatar
Mike, it's not that I am stubborn, just like to try out new ideas
Yes, many has suggested front center monted cooler, many has also said ithe 2 I have should be enough.
If I'm failing, it will be a lesson learned and a hell of a lot work for nothing
But looking at the GT2 EVO, they did it without center mounted cooler.
I have also repositioned the coolers and cleaned them
Trond R.
1986 944 Turbo
Old 07-29-2014, 12:15 AM
Brando
quattrorunner's Avatar
Those are some big ol air gulping holes. I think you'll be fine with regard to cooling. I have coolers in each side as well but my next bumper makes the center mount more handy so that's what I'm doing. Not because I need to though. You'll get it right I think.
Turbo powa!
1977 911s. it's cool
Old 07-29-2014, 01:02 AM
totle's Avatar
Painted. Tested out my new Eastwood HVLP paint gun
Will make some direct ducting on the oil coolers, then final installation :-)
Trond R.
1986 944 Turbo
Old 08-02-2014, 03:08 PM
gavinc69's Avatar
Nice work
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 08-03-2014, 08:46 AM
totle's Avatar
Now I think it will breath more :-)
Trond R.
1986 944 Turbo
Old 08-06-2014, 03:54 PM
DSPTurtle's Avatar
That looks awesome!!!
Old 08-06-2014, 05:21 PM
Brando
cooling issues done
Turbo powa!
Old 08-06-2014, 05:24 PM
Banned
Wow Trond - very impressive work - looks great and I bet it works, too!
Old 08-06-2014, 05:53 PM
