Time to upgrade Jeff NJ's 930
So last spring I started a thread about what my options were to upgrade my car here: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/806512-lets-upgrade-jeff-njs-car-thread.html
Got lots of great advice and talked to a bunch of great people about it. I've had my 930 for just over a year and have put almost 3000 glorious, ***** eating grin miles on it. My clutch has been giving me some issues as I can't get it into reverse when the engine is warm without grinding the hell out of it. I replaced all the stuff outside the motor (omega spring, cable, pedal bushings, etc.) to no avail, so its time to pull the motor and see what is wrong with the clutch. I am thinking either the shift fork is worn or bent, or the pilot bearing is failing. Either way, motor is coming out and I figured while I'm in there, time to upgrade! I'll also be changing a bunch of leaky gaskets and seals and some other "while your in there" maintenance items. Everything coming off is getting boxed up and packed away in case the car becomes more valuable in stock form if I ever sell. I have everything disconnected from the motor and am ready to drop it. Some friends are coming over Sunday to help with the drop, so hopefully I'll have pics of the motor out by Sunday night! Here is what I'm doing:
I'm hoping for about about 400 HP compared to 282 stock and considerably more torque too. Opinions on HP/TQ gains? I am planning on dyno'ing it once I'm done to validate the butt dyno. Should be a fun and educational winter project. I am a little nervous about my first engine drop, but I know that the brain trust here will help to get me through any issues that come up that are beyond me. Here are some pics of the parts along with some before I started and where I am now shots. Headers and Tial are not here yet, so those pics will have to wait. Brian is almost done with my headers! I figured I would post up as I make progress with some pics (engine out, clutch inspection, parts install, etc.). This will take me a while, but I have all winter, so I'm in no rush. Wish me luck!!! ![]() ![]() ![]() ![]() ![]() ![]() A bunch of stuff that I've removed so far: ![]() Here is what it looked like before I started: ![]() Here is where I'm at now: ![]() ![]()
1988 930 Venetian Blue |
Sounds like a fun build. Seems like your 400 crank hp is in the ballpark. I know my car made about 330whp when it had a k27. A J&S safeguard would give you some peace of mind especially since you're increasing power and have it apart already. Cheap insurance after all the money you've already spent.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
beancounter
You're going to be busy thus winter. Don't worry too much about the absolute hp#...the combination of all this work, both engine and suspension, is going to completely transform your car. Your $hit eating grin is going to get much bigger. Do not get greedy with boost level, and do verify that your distributor functions properly. Check total advance, and check that the timing is properly retarded under boost pressure.
Not sure where in NJ you're located, but if I can offer any tools or moral support do let me know.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
PorscheMoparLiterbike
Nice....looks similar to what I was doing last year! no suspension though....
Some random thoughts Lots of threads on engine drops - make sure you have the jacking/stands height to get the engine clear - dont forget the Bosch multi pin connector to the right of the driverside shock mount Looks like you've spoken with Chris - TK sent me a "Do all these gaskets/seals when engine is out" package, front rear main seal, oil sender, breather etc I also replaced the stock injector blocks with TK billets May need some cams to get to the HP goal - level of difficulty higher Check/replace engine compartment seal while your in there Check air box clearance with the IC - may need cone filter k27 vs LDZ mounting and orientation Air injection system - leave in or out.... How about an MSD ignition/coil...plug in to your existing harness no cutting...JFairman has some good thread and pics I used Assuming you have K-Lambda system with oxy sensor....... if keeping.....after reassembly make sure ground wire on inner stud for fan housing is solid....caused all kinds of problems...thanks Ronnie for troubleshooting The voices in my head have stopped..................Beautiful 930....Have fun ![]()
88 930 BnB Kinesis tial 1bar k27/29, Turbokraft IC+blocks+rokr loks+ ported intake,edelweiss cams, KEP/Sachs, Verden Tool 38mm PP heads, ARP bolts/studs, twin plug for future |
Hi Jeff
Good Luck! First i have to say the Customer Service from Chris is nice! I see you have the IC from Chris, maybe you will have the same problems as I with the fitting. #1 conflict with the air filter box #2 connection to supplementary air slide wrong #3 Connection to the turbocharger intercooler welded wrong (can`t close my tailgate) Ask Chris for a solution he is absolut helpful
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods Last edited by 930/66; 02-10-2015 at 08:14 AM.. |
3 restos WIP = psycho
You're on the border of a high performance clutch upgrade. When I did my motor, I ended up with an unbudgeted $2500 surprise. The Sachs BTR clutch and adapter is the only option for high performance engines that retains light pedal effort. Be wary.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Jeff- happy to hear you are making the mods you wanted just a year ago!
I have the black TK IC. It's fantastic and keeps a "stock" feel to the engine bay. You will need to notch the air box or go the cone air filter route. I'll sell you my cone filter if you want it b/c I went the notch route. Also, my mods are nearly the same. I did include a lightweight pressure plate and Sachs clutch. Big difference in revability (that's a new word). Props for taking on the drop! Good luck Will |
I'm going to look into the J&S. Probably a dumb question, but would an MSD6AL have a knock sensor and provide similar protection? Or can they be used together? I'm on the fence about MSD...
Yeah, I'm not too worried about the actual HP. It's more to validate the gains via the upgrades. I am thinking either .8 or .9 bar spring. On their website, Tial states to get .3 bar lower than the desired boost when you have aftermarket headers due to lower backpressure. So I guess a .8 spring would really be 1.1bar? Is that correct? Thanks for the offer. I think I have the right tools (we'll see...), but I do see me picking your brain on occasion. I read your motor rebuild thread and it was great. So much good info in there. I'm hoping I don't need to go that deep. I am in Morris County (probably 45 mins from the Holland Tunnel.)
Yeah, I've already budgeted for a clutch. I'm just waiting to see what I've got in there before I buy anything. It was replaced by the prior owner, but the receipt doesn't state what, exactly was replaced, or what brand it is, so who knows what I've got... Eyes wide open and hoping for the best.
Chris at TK was very helpful. Lots of good tips. Brian at Rarlyl8 helped me with the k27 mounting. Engine compartment seal looks fairly good from what I have seen, but will replace if necessary. Air injection is going. K-Lambda may be going. Not replacing cams (this time) Not sure about MSD. Would it help with my build? thanks!
I dont work for John at J&S or anything, i'm just really happy with the system on my car so I try to spread the word. I can finally take my eye off the AFR gauge while driving since I know even if there's an issue the J&S will protect my motor. He's very helpful too if you have any questions. I exchanged probably 20 emails with him before I ended up purchasing the safeguard.
Nice progress so far. Keep the pictures coming.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() ![]() ![]() |
beancounter
Jeff,
Couple things...I noted my max boost dropped when I installed higher performance exhaust (mine is an SSI system). Rather than change wastegate springs, I just put in a manual boost controller. The "dial-o-death" knob is in the engine compartment, so I don't have temptation to crank it up as may happen with cockpit adjustability. Regarding clutch, my car had a basically brand new OE pressure plate and standard Sachs spring center clutch disc. I have no slippage issues, and that's with something around 375 wheel HP. YMMV. For brain pickin' just PM me sometime and I'll give you my cell number. If you're ever near to Jersey City, look me up. I'll show you my little workshop and current project: ![]()
Banned
nice Jeff - way to jump on in there
as was said, what you've got planned will literally transform your car from awesome to uber - drivability increases immeasurably (regardless of dyno measurements), and your satisfaction / gratification will be immense best is the sense you'll establish with your car - you'll learn much about it, and you - good stuff I def yoinked ^said^ Bosch multipin connector by the inner / left shock tower, got caught up in the haste of trying to have 1000hands @ the same time whilst disconnecting / lowering things my thoughts were largely covered above, but random thoughtlessness: engine sound pad scrape-age and/or replacement is good while yer in thar - yers looks as insipid as mine as is engine seal - you'll be surprised how brittle/dry you'll find yers is, all over but most especialliest by the turbo - replace it recondition yer tin too a bit whilst it's out - check for rust by turbo def consider cams - you're right there, doin valves, just a special tool (Ronknees' nickname?) away from 'em - why not. My SC's really changed the overall character of my powerband, almost want to say the gearing feel too... lovin it. plus you get to attend to some good leakprone sealage too whilst at it... chain covers, chain box, cam ends, etc. (and be like me and have something still leaking now afterward - awesome!) ![]() RSR rocker seals - $80 well spent do the rear breather coupler hose whilst in thar, and any / every seal you can get to... oil cooler, oil pump, oil tstat, turbo / muffler / wastegate, etc. I v-banded my turbo / muffler flanges whilst out - non-eggzachry lined up tips (and tits too, for that matter) ultrawicked urk me... v-banding is smart easy cheap flexibility lube yer throttle linkage thoroughly whilst you have access to it new vacuum hosiery if you do go cone filter, DO add a catchcan - venting to atm FTMFL!!! (reference the Bongresin in my Cabin Fever thread - Just Say No) invest in Massenguil and rags and douche the beejeebus out of everything mebbe set aside some polishing time - I love me some nekkid aluminum smiling at me, I'm not a powdercoater... au naturale baby change gear oil, trans tailshaft seal (mine was leaking into the tunnel box pretty visibly @ 60k) jah... clutchslippage... I'm there now... 20k on OE spring centered clutch then increasing to ~420+chp has mine slippin somewhat... by the book / read it Lookin forward to updates! Def take Jakester up on his offer fer tewls / wisdom / etc... he's encyclopedic with his P-wrench knowledge and assistance, and always is a voice of blunt realism Last edited by krasuskyp; 01-09-2015 at 08:13 PM.. |
Banned
ps. I went MSD... seemed to make good sense
pps... remove / store all OE parts to preserve value or sell them all for the difference in value you'll not receive later down the road was a no brainer for me... half my mods cost me literally zero... hmmm plus knowin my bits were doin someone out there some good (errrrrrr) rather than collecting mold 'n rust on the shelf? Priceless. Just sayin... |
Banned
Paula, I've got yer "special tool" right
![]() Two minutes, three times daily = Paul's errrr ummmm "polishing" regimen!!! Jeff, sweet project(s), and like other's have said, when you next drive the car, you'll be saying "stock is fer Paul's Christmas gifts"!!! Last edited by Ronnie's.930; 01-09-2015 at 08:57 PM.. |
The MSD is good for availability and cheaper replacement. 30 k miles without problem on mine. Some opinions on bigger spark gap etc. I have the programmable for some 2D mapping in the future. Lot of lower end gains based on others experience. Havnt had a chance to try yet.
I like my klambda....runs cleaner and little better gas mileage when I'm not hammerin on it. As Paul said, cam upgrade is nice..better off boost driveability and more power everywhere. TK set me up with a KEP pressure plate and SACHs organic disc...little more pedal effort and grabbiness but lot of grip and no issues after 10k+ miles In the slippery slope category.. This might be the time to go through the gear box.. Also take extra care when mating the gearbox to the engine on reassembly...make sure the release fork pivots in back of and sits on the throwout bearing tabs correctly
So the motor is out!! Went very smooth, mostly because of all my prep work that I only would have known about from here. Thanks for all that have posted engine drop threads in the past!!
![]() ![]() ![]() So my first order of business was to check the clutch since that was the primary reason for the engine pull. Got the trans separated without issue. Clutch fork looked good. Pressure plate looked OK to me. ![]() Time to pull the clutch to see what that looked like. I'm not sure, but I think this may be an issue... ![]() ![]() So I'm quite shocked that I was able to drive this at all with the clutch the way it is. I already budgeted for a new clutch, so not a big deal. Suggestions for a new clutch? I want stock clutch pedal feel if possible. I don't track the car and I don't see me going over 400 hp at the flywheel. (famous last words)
At that power, if you want stock pedal feel, my previous warning applies...Sachs BTR setup.
