930 Track Sparkplug Recommendation
Looking for the best plug for 930 track use.
1980 930
Stock turbo .8 bar
Stock CDI
SSI Headers, no muffler
I'm assuming a colder plug like the NKG BR8EIX is a good choice.
Recommendations?
And, what should the gap be set at for stock CDI.
Jim
1980 930
1995 993
Old 07-24-2015, 08:22 PM
T77911S's Avatar
dont think i would use the iridium. the CS plug is a good one. dont know how many are running the coppers.
8 or 9. start with a 9
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-27-2015, 05:57 PM
River Rat
Dave 86 930 Fl's Avatar
I've run stock plugs for years, no issues or complaints. $16 each from our host.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 07-28-2015, 03:55 AM
930T Owner
Hams930T's Avatar
I use a Denso IW-24 which is their heat range 8 iridium plug. They also make a racing version of that plug but I've found the standard iridium version is pretty awesome.
Hams930T
2017 Turbo S
Old 07-28-2015, 07:15 AM
Turbo Hooligan
I run copper resistor autolites, equivalent heat range of a 9. gapped at 23 thousandths
D-Zug
Old 07-28-2015, 07:34 AM
Ingenieur
Don't torture your poor little stock CDI with a resistor plug. It will just get even hotter than normal, and deliver less energy at the gap.
Why change from a 0.2mm platinum electrode to a .4mm copper electrode? Seems like the wrong direction to me.
Old 07-28-2015, 12:05 PM
+1
or use the IK-24 with a smaller 5/8" hex. Easier to change.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 07-28-2015, 12:51 PM
Thanks guys.
I'm bringing a 1980 930 back to life and want to update the plugs. My former mechanic used some Champion from a long time ago. The car has been idle for over 10 years so is getting the fuel system and mechanical go over before restarting.
Lot's of opinions to consider here.
Jim
1980 930
1995 993
Old 07-30-2015, 07:38 AM
