930/66's Avatar
New K27 Based Turbo
I have currently a K27 Hybrid Turbo (original turbine wheel with 61mm holset compressor) from Brian.
It`s absolute nice for freeway and track.
For normal street use is it a little bit laggy.
I have ordered a K27 based new KKK (journal bearing) with an other turbine wheel (same dimension but other geometry (flater) for better response.
Compressor wheel is a billet 57mm 7 blade).
Here some Pictures frome the new one:
left side new / right side old:
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 12-21-2015, 11:33 AM
gavinc69's Avatar
Nice...be interesting to see what you think of it.
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 12-21-2015, 12:01 PM
Banned
^2nd^
Old 12-21-2015, 04:40 PM
puddy's Avatar
Cool, did you get the new compressor wheel from Brian?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 12-21-2015, 06:36 PM
The exhaust turbine wheel looks like the blade at 8 o clock with the paint stripe that was put there during the balancing process is longer than the others.
Was the turbine wheel clipped?
Old 12-21-2015, 06:48 PM
930/66's Avatar
No it`s from ETG Eichner, Germany, he makes many jears turbo`s for Porsche`s
Old 12-22-2015, 08:23 AM
930/66's Avatar
Yes look like the blade is longer, but it is not.
The turbine wheel ist not clipped, it has additional to the other geometry a wheel Cutback.
Old 12-22-2015, 08:35 AM
Having the exhaust turbine wheel blades clipped a little shorter is an old way to lower back pressure before the turbo for better top end performance. Bob at Durabilt turbo told me about that some years ago but I've never seen pictures of one thats had that done.
It looks like a Garret exhaust turbine wheel in the 3K housing.
Thanks for the information.
Old 12-22-2015, 08:38 AM
930/66's Avatar
That is interesting, thanks!
I really don`t know about the turbine wheel (brand) i check the garrett page, only the GT 20 Serie has 12 blades but there are to small.
The easiest way is to ask ETG about the brand.
Old 12-22-2015, 09:38 AM
930/66's Avatar
Some detail pics:
Old 02-29-2016, 10:07 AM
Chain fence eating turbo
Not clipped.
Old 02-29-2016, 10:26 AM
930/66's Avatar
Some Bad Update
I'm a little pissed
This Turbo never run really on my Car. Before 6 months I have mounted the turbo for the first time. Testdrive oil hot...red light (traffic)....smoke, s...
Back to supplier / error causes wrong bearing housing (deja vu)
Turbo back with new bearing housing...second attempt...
lock that one:
https://youtu.be/YGusdMM8MgY
https://youtu.be/xOnWuaSZqd8
Again a wrong bearing housing......
What i really not understand is the bad controlling from the suppliers.
Turbo is back to supplier...money is back...now i look for a Garrett!
Old 06-09-2016, 02:15 AM
930/66's Avatar
Here you can see a scratch from the turbine:
also bad (back plate from compressor housing is a Czech copy):
End of Story
Old 06-09-2016, 02:20 AM
proffighter's Avatar
Hi Thomas
Bad story, I feel your anger. Only left to look forward. Can't wait what turbo you choose and how it performs.
Roland
930 Turbo '81 Too many modifications to list
Old 06-09-2016, 03:36 PM
Garret GSX 61 is another good option.
They said you can think of it as an upgraded Blowzilla.
Old 06-09-2016, 06:50 PM
930/66's Avatar
Originally Posted by proffighter View Post
Hi Thomas
Hi Roland
I think positiv and find the right one!
Old 06-11-2016, 05:45 AM
930/66's Avatar
Hi Jim
I see the GSX 61 also as a good option...for that price you become alot of turbo!
Old 06-11-2016, 05:48 AM
They are built from a Garret TO4Z.
You can order them with a cast or billet compressor wheel and with journal or ball bearings.
A couple years ago they ranged from around $850 to $1200 depending on the bearings and compressor wheel used.
I bought mine from the manufacturer: Turbos Direct in Arizona with ball bearings and the billet wheel. It was around $400 less than a new GT35R back then. It works very well and never leaks or smokes.
Old 06-11-2016, 08:04 AM
Mr9146's Avatar
This is why Bob at Durabilt is the best.
Old 06-13-2016, 08:53 AM
930/66's Avatar
Hi Marco
Is he still in Buisness?
Old 06-13-2016, 09:15 AM
