Alan L's Avatar
Originally Posted by krasuskyp View Post
thanks Alan - dumb question... is there supposed to be a crush washer under that fitting? I'd 'thought' it was a ball / compression fitting?
If we are talking about the same fitting - the big oil union that screws into the lower engine case - your driver side, yes, it is a crush washer - just crawled under mine to check (is on trailer). So, I would first try and verify which bit is leaking - no point pulling apart a good seal. at worst you could wipe the area down with brake kleen, and run it briefly and check to see where the drip forms - on the case, or on the union.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-17-2017, 03:18 PM
I had my Rob Siegel European Electrics manual ready to crack open to the alternator chapter but went for the easy stuff first; lo and behold, a loose nut on the chassis ground strap. Big roadblock for electrons. Paul swung the geardrive 13mm wrench so he could say he fixed it. I was grateful we didn't have to pull the alternator. John.
Old 07-17-2017, 07:19 PM
starter issue?
My starter ring was so chewed up it was unserviceable. We got a new flywheel starter ring from porsche. I wanted a new starter but my mechanic said the starter was a ok. After reading this thread I'm wondering if the alternator is a persistent issue on some 930s. My starter ring has now been replaced twice in and my 930 has 51,000 miles..
http://9309700485earlyturbo.wordpress.com
Old 07-25-2017, 11:54 AM
I also need to replace my 12 year old optima red top battery. It's still going strong though..
Old 07-25-2017, 12:02 PM
