Engine run stand
Kind of off topic of this forum…..but having engine built for restoration project.
We would like to run engine in …….as body won’t be ready well beyond completion of engine.
Any information on building or buying ( reasonably) an engine run stand would be appreciated.
TIA
TOT
Old 01-09-2025, 08:00 AM
The 9 Store
There’s some being sold on Amazon that seem to be good. I remember it being about $500.
All used parts sold as is.
Old 01-09-2025, 01:57 PM
TIA
here's a few vids...
https://www.youtube.com/results?search_query=porsche+engine+run+stand
One of them is my cobbled together version.. it's ugly, but works well!
Always learning.
www.aircooledporsches.com.au
Old 01-09-2025, 02:37 PM
Response
Access t videos made easy!!!!
TOT
Old 01-09-2025, 04:59 PM
I happened to be about an hour away from JB Racing in Eustis, FL. JB Racing did the machine work for my rebuild, so, after I put it together, (10 years later!), I scheduled a day on their engine dyno. Excellent facility and very knowledgeable folks-well worth the time and expense. I toyed with the idea of building an engine stand, but I’m glad I didn’t.
dho
Ocala
Old 01-10-2025, 04:38 PM
Years and years ago, I used a borrowed Stuska dyno on my 911 engines. Fast forward a few decades and I opened an engine restoration shop for 356, 912 and pre-'73 911s. I built three running stands for those types of engines. I hate to be leaning into an engine compartment while tweaking and tuning the fresh engines. The running stands weren't too difficult to engineer and build but I don't think I would have done then if it was only for one or two engines. Three years ago I bought a used Stuska dyno and still haven't had the time to hook it up.
Old 01-10-2025, 05:14 PM
targa72e's Avatar
I built mine out of wood and used a old 901 transmission case. Not pretty but gets the job done. I currently have my 5th engine on it. Added wheels so it was easy to move around. Its screwed together with deck screws and can be disassembled so not a big item to store.
john
Old 01-10-2025, 09:35 PM
I am my 911's PO
'78 SC's Avatar
engine stand
I rented this stand from a local shop. It uses a fabricated adapter instead of a 915 bellhousing for front support and starter mount. There was a similar adapter in the classifieds recently.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 01-13-2025, 07:16 AM
john
Hi John,
Love that non-traditional ingenuity that gets the job done. Can you post a picture from the other side as well and include the mounting points?
76 911S Signature Edition w/ 3.2
Old 01-13-2025, 10:05 AM
Stand
Thanks for pics
TOT
Old 01-13-2025, 08:57 PM
You can contact me directly for engine test stand parts from Zalex Industries.
We make the starter adapter bellhousing pictured above as well as an entire support frame with oil tank support.
The 911 stuff isn't on our website, but it can be made to order.
Here's a video of my engine on it.
https://youtu.be/ZPhB-Q1cKBI
Tom
858-243-0476
www.ahhgaragetime.com
Old 01-13-2025, 10:49 PM
911 tweaks's Avatar
bump.... any one else with their engine stand set up...?
I live for 911 tweaks...
Old 12-01-2025, 12:01 PM
Old 12-02-2025, 11:12 AM
Originally Posted by ddinham View Post
That's nice and clean.
Sadly, being able to cut and weld metal cleanly is something I will never master in this lifetime!
Always learning.
Old 12-02-2025, 11:14 AM
I can’t take credit for it. This is a test stand that Zalex used to sell many years ago. The same person that still sells the adapter ring still currently available.
Old 12-02-2025, 11:21 AM
Engine Stand comment
My buddy built one for our purpose …….one lesson learned was design should consider factory oil lines to tank otherwise you will get stung having those made. The design is fine functionally but one posters photo showed angled sections that allowed oil tank to be positioned for use of factory lines…
TOT
Old 12-02-2025, 12:06 PM
911 tweaks's Avatar
Thx for all posts…
Old 12-02-2025, 12:47 PM
If you care about your engine , it should be run on a dynamometer not an engine stand .
Old 12-08-2025, 06:54 PM
Run stand
Would you mind explaining….
Seems like a blanket statement without any rationale. …..
TOT
Old 12-08-2025, 07:50 PM
If you are talking about a danger involved with running these engines without a load on them...that would also be the case if you started and ran the engine in the car while parked.
I don't think anyone is attempting to perform the entire engine break-in procedure on an engine stand- just the initial start and cam break-in (which should not harm anything).
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 12-10-2025, 04:19 AM
