fastfredracing's Avatar
Oem bearings or Glyco, any difference?
I have heard of some qc issues with Glyco in recent years, any truth to this ? I have also always assumed that when you bought oem, you were getting Glyco in Porsche packaging.
I should have some boxes back from the machinist in the next couple of weeks, so I have to start getting my parts list together. Don't mind spending the extra coin, just want to make sure I am getting what I pay for.
No left turn un stoned
Old 07-06-2011, 06:31 PM
I heard that the rod bearings from aftermarket supplies have had some issues lately as well. I tried to order Factory 2.4 rod bearing shells and Stoddard had 3 half shells and the rest would have had to come from Germany. And the cost would have been almost $400 for just the shells. I could not wait a month for the order to arrive, so I used the aftermarket ones(15 year old stock) that we supposed to be ok. I am no expert, but my machinist is and confirms that there is an issue, either in the composition of the materials, or something else has changed. From what I understand is that under severe racing conditions they just do not hold up.
2000 VW TDI 224HP/400FT TQ.
Pikes Peak World Record Holder 2007 "Fastest Diesel Car"
1973 Porsche 914/6 2.4L Engine rebuild in progress
Old 07-06-2011, 06:47 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep the guys in the know that do this work on a daily basis have confirmed the aftermarket Glyco bearings are notsogood these days. Here's some comments from the experienced when friend cstreit had a problem with his engine.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/521208-bearing-still-crap-my-oil.html
Kevin L
'86 Carrera "Larry"
Old 07-07-2011, 10:25 AM
txhokie4life's Avatar
GT3 rod bearings ok for 964 crank? WRONG -- see next post
GT3 mains are not -- is that correct? ARE OK -- see next post
Any experience with SmartRacing Calico Coated Rod Bearings .... other than they're not cheap....
M
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-07-2011, 11:56 AM
BURN-BROS's Avatar
M
Other way around.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-07-2011, 12:09 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I had previously used Clevite 77 bearings when rebuilding my friend's 911...but after checking online...I can't seem to find them in Clevite's latest catalog.
I prefer them to any other...because they came with grooves already machined in...and had hardened back shells.
They were available in several different styles...some with radiused sides to get better oiling.
I have also seen a set with what appears to be a "leaf" style set of grooves in the surface to promote oil dispersion on the journal.
Good luck in the rebuild.
Bob
Bob Hutson
Old 07-07-2011, 02:27 PM
