Main oil galley plugs
What's the best solution for replacement plugs? I hear the new plugs form Porsche are too large. Is this true? Is a pipe plug the best alternative? I recently enlarged my center main to go with my grooved bearing from Henry and cross drilled crank. I knocked the plugs out to flush the block and now need to install a replacement.
Old 05-03-2014, 08:16 AM
abit off center
cgarr's Avatar
I think I had to turn down the factory plugs the threaded plugs are too deep to work.
Here are the two don't remember but I may have just made my own plug it was for an RSR case I was working on. The factory plug here is .870
______________________
Craig
G2Performance
Old 05-03-2014, 09:40 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I like screw in pipe thread style plugs.
They are positive leak control...removable to service...and easier to install (depth control).
If you use the allen key style plugs...they can be very shallow and are available in several different metals.
Bob
Bob Hutson
Old 05-03-2014, 11:34 AM
abit off center
cgarr's Avatar
Problem with the plug in this area if it's where I think he is putting it, there is an oil passage right behind the plug that would be covered if a threaded plug was used.
Craig
G2Performance
Old 05-03-2014, 11:40 AM
I have actually only removed the front plug and don't see any need to remove the rear.
Could the front be tapped with no issues?
Old 05-03-2014, 12:51 PM
abit off center
cgarr's Avatar
There is no room for a threaded plug in either end.
Craig
G2Performance
Old 05-03-2014, 04:40 PM
neilca's Avatar
I have been chasing oil leaks from a PO threading the oil galleys in a 4 cylinder. The guy did a lousy job of threading. Best bet is to not remove the plugs, second best go through the pain of fitting plugs, third thread for plugs. That is my opinion and what I practiced on my last race engine.
Old 05-05-2014, 03:17 PM
I had no issues with the large size front and rear oil gallery plugs from the Porsche dealer, fit perfect. It was the smaller ones, top and behind fan, that did not fit and those were easily threaded for screw plugs. This was for 2.7 mag case though.
Old 05-06-2014, 11:42 AM
Walt Fricke's Avatar
You can make a screw plug work on the front main gallery,but you have to be very careful. I figured out a way to know how deep in I was screwing the plug, and marked the outside so I could get it just right, and then ground a groove into the inside of the plug so it wouldn't partially obstruct the opening on the side. Seems to work fine.
If I had a lathe, maybe I'd just replug. For that matter, a guy could make his own with a lathe, couldn't he? But, alas, I don't have room for a lathe.
Old 05-11-2014, 05:20 PM
I went the factory plugs which measure in about .002-3 over the factory hole... has anyone installed these? Heat, dry ice, 574??? Any tips on installation.
Old 05-13-2014, 04:17 AM
HawgRyder's Avatar
If you install a push fit plug...by all means freeze it first.
If it becomes a push fit with fingers or light push with tool...then you probably have the correct fit.
A little sealer would not be overkill.
And Walt...yes...a lathe is the answer....have had several over the years...makes a great addition to the shop...and being cheap like me...I make all sorts of things to save money or just move projects along without the need to wait for parts.
Bob
Bob Hutson
Old 05-13-2014, 10:48 AM
abit off center
cgarr's Avatar
Craig
G2Performance
Old 05-19-2014, 01:39 PM
