930/66's Avatar
Camshaft Adjustment with 964 Spec
Camshaft Timing Adjustment with 964 Spec.
1.26 mm left / right
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 08-16-2014, 09:57 AM
930/66's Avatar
Installing Spray Tube / Spark Plugs / New Seals
Installing some Parts:
Old 08-16-2014, 10:07 AM
930/66's Avatar
Installing Valve Cover with Silicone seal
Nice Silicone Valve Cover Gasket Set from Pelican.
I have also ordered the Complete Case Hardware Super Kit
Old 08-16-2014, 11:56 AM
930/66's Avatar
Assembling Oil Cooler
Old vs New
Old 08-16-2014, 12:03 PM
930/66's Avatar
New Distributor Cap and Oil Pressure Sender Unit
I had some Problem with Oil leakage so the Sensor had to be replaced
Old 08-16-2014, 12:13 PM
930/66's Avatar
Cleaning / Checking Oil Scavenge Pump
After Cleaning and Checking the Oil Scavenge Pump i have replacement the Seals
Old 08-16-2014, 12:29 PM
930/66's Avatar
Installing Oil Scavenge Pump
After Installing the powder coated motor sheets:
I have mounted the pump:
Old 08-16-2014, 12:34 PM
930/66's Avatar
Assembling New Lightweight Clutch Systems
930 Lightweight Clutch Systems from Patrick Motorsport with all Parts
Old 08-16-2014, 12:44 PM
Love to see posts like this. All the new parts, clean work area, all the cleaners, lubes and sealers. We should all be so fortunate to have such a well equipped work area.
I just have one problem, along with JOE-1972, why didn't you strip the case of all plugs, especially the oil relief valves, etc. and send it out to be cleaned? Have you found any of those bits of aluminum that you ground off to do the boat-tail in the oil screen yet?
Bob B
Old 08-20-2014, 02:02 PM
930/66's Avatar
Bob B
Hi Bob
First Thanks for the kind words.
You're right the procedure was not optimal the decision the oil relief valves and all Plugs to remove came after machining and assembling that`s not good.
I have cleaning myself the case (about 3 hours). I found no bits of aluminium from that modification (large particle) the photos after the first oil change I will post at the right time.
Thomas
Old 08-26-2014, 03:55 AM
930/66's Avatar
Installing Oil Supply Pipe and Cover Timing Housing
Old 08-26-2014, 05:08 AM
930/66's Avatar
Installing Red Cover / Wide Clamp / Knock Sensor
Old 08-26-2014, 05:11 AM
930/66's Avatar
Assembling Motor Harness
Old 08-26-2014, 05:38 AM
930/66's Avatar
Assembling Alternator
Old 08-26-2014, 05:45 AM
930/66's Avatar
Installing Hot Air Socket`s / Oil Feed Line
Installing Oil Feed Line from TK:
Installing Hot Air Socket`s:
Old 08-26-2014, 05:56 AM
930/66's Avatar
Installing Engine Cover / Brackets / Oil Return Pipe
Installing Engine Cover`s and Bracket`s:
Installing New Oil Return Pipe:
Old 08-26-2014, 06:32 AM
930/66's Avatar
Installing Coil and Spark Plug Wires
Old 08-26-2014, 06:41 AM
930/66's Avatar
Installing TurboKraft's CIS Injector Blocks bore size 36mm
The CIS Injector Block-Kit from Turbokraft is absolute amazing!
Old 08-26-2014, 06:52 AM
930/66's Avatar
Assembling / Installing Intake Manifold
Assembling Intake Manifold with some new Parts:
Old 08-26-2014, 07:01 AM
930/66's Avatar
Assembling CIS Unit / Installing Crankcase Bleeding Line
Old 08-26-2014, 07:16 AM
