930/66's Avatar
Alu Flex
Originally Posted by Pat RUFBTR View Post
Hello 930/66,
To avoid of installed(settled) this thermal protection there is another solution than I envisage seriously, that to make a ceramic treatment(processing) on the collector of escape by the company Zircotec, it is not given but do not apparently very effective.
I have just joined but I am your restoration(catering) for a long time as that Spenny-b, bravo, your work is great(tremendous)!
That can be a good solution with the ceramic. I want go another way, i change the diameter from the headers (heat-Box)
I want install the flex alu tubes (like original). Before i had headers from Fabspeed with the alu flex.
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 09-06-2014, 05:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
930/66's Avatar
First Start
Before I started the engine for the first time after the Engine Conversion I have performed all points on the checklist according to Wayne's book.
After that i start it...
Porsche 930 3.4 First Start after Rebuilding - YouTube
and let it run for 20 minutes Idle between 1800 and 2000 U/min.
First Oil Change (by Wayne's instructions) he describes in the book that some think that this is exaggerated....i think not.
Old 09-06-2014, 05:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
I also have this collector Fabspeed but he is modified to receive a discharge(dump) Précisionturbo PW66. Diameter internal of the collector is of 35mm, it is a little bit just for the 38mm in the admission, I would need your escape Rarly8 but with a v-band of 60 mm (PW66) in discharge(dump). My turbo is précision turbo 67/66 ar 0.82, The discharge(dump) of origin was not sufficient.
Old 09-06-2014, 04:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
930/66's Avatar
Looks amazing
How work the précision turbo?
My ist a K27 with a K29 compressor.
Old 09-10-2014, 11:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
930/66's Avatar
1. Drive on Street
After the 1. oil change (with filter) i drive the first miles on the street.....
After 20 miles test drive I have blue smoke:-(.
(Just blue smoke when the car at standing gas)
I expanded the turbocharger to find the error (everything was oily cold and hot side).
Old 09-10-2014, 11:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
930/66's Avatar
Find the Error
With the helpful support of brian (Rarly8) i check all possible source.
- oil line check ball is in place at the sending unit
- measure the flow of the oil to the turbo and the scavange flow back to the pump
First i check the check ball:
all right!
Second measure the flow: (the difference of cold and warm oil is huge)
The problem ist just with warm oil (more flow)
Flow-Test #1 cold Porsche 930 Scavange Pump cold start - YouTube
Flow-Test #2 warm Porsche 930 Scavange Pump hot start - YouTube
Old 09-11-2014, 12:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
930/66's Avatar
Measurements
The amount of 2.5 L/min Oil going through the K27/29! (measured at the outlet) The pump can`t pump that away to much oil.
I have the old line fitted with the old (original) banjo bolt ( internal diameter of 6mm),
the banjo bolt from Chris TurboKraft has a internal diameter of 8.5mm (for the Spring) and a 9mm Check Ball both measurements were the same.
Then i have changed the turbocharger from K27/29 to my 28 Jears old 3LDZ and the Problem was solved.
With the K27/29 i measured 2.5 L and with the 3LDZ 0.75 L/min. (warm)
My Friend has measured also with his K27/7200 0.8 L/min.
Old 09-11-2014, 12:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Turbofrog
smurfbus's Avatar
I had to put a restrictor of 1.5mm on the turbo oil feed line to stop my Holset from overfilling the scavenge side.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-11-2014, 03:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
930/66's Avatar
That was not the problem it is the K27/29 itself!
With the 3LDZ was all right!
Old 09-11-2014, 10:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
930/66's Avatar
I have send the Turbo back to Brian for check it
I have found a picture of my old K27/7200 (sold a few years ago) see at the oil outlet no hole
The K27/29 have a rectangular hole that looks not original, maybe thats the Problem.
K27/7200:
K27/29:
I talk with a turbo Guy from here. There are 124 versions of the Bearing housing with 4 different slide bearing for the K27 Turbo.
Then came the Turbo back from the repair:
The bearing housing was replaced as the original had been modified for use in a racing application requiring more flow than the standard 930 system.
Brian has reimburse my shipping cost as well
The Support and Help from Brian is absolut amazing!!!
Old 09-11-2014, 10:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
930/66's Avatar
Second Installing of the K27/29
I drive with the 3LDZ about 400 miles (run in the engine).
Then i change the oil and filter again (from 15W-40 to 10W-60).
That was the right time to install the K27/29 again (after the repair).
I have the turbo and engine over 500 miles (with max 0.4 bar) run in.
The car runs at 0.4 bar very good
The Sound from Brian`s Headers....
Old 09-11-2014, 10:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Looks amazing
Hello 930/66,
With regard to(Compared with) my former(old) K27 / 29 which loaded(charged) from 4000 tr / mn, precision turbo loads(charges) much more early in approximately 2400 tr / mn, this is certainly due to the ceramic rotations. The car seems much more coupleuse to low diet(regime). My exit(release) admission turbo towards the heat exchanger(interchange) Ruf " modified by myself(by my care) " is in 3 " throughout. If that can help you for your turbo which has some oil in the body of admission, I had the same problem with mine, I had to forget to remove a cork which I had put to protect the engine when I had him(it) to defuse(unsettle) for the first time. The oil was blocked(surrounded) to go to the pump to oil of the camshaft. Maybe you have also forget something, needs to verify everything. Good luck!
Old 09-11-2014, 12:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
930/66's Avatar
[QUOTE
Maybe you have also forget something, needs to verify everything. Good luck![/QUOTE]
It was really the Turbo
Old 09-21-2014, 07:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
930/66's Avatar
Again Blue Smoke
3 weeks ago I have set the boost pressure to 1 bar for 50 Miles all fine / Turbo works good!
After that I've noticed the boost pressure builds on stutterly......an then blue smoke...oil.oil...oil.
First i cleaning all and change again the turbo to my old 3LDZ = test drive = no blue smoke
I have send the Turbo back to Brian for a second one....
we will see whats happen...now I'm waiting for a response
Old 09-21-2014, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Hello 930/66 ! Well, at least you know where from comes the problem, even if it is irritating to have to clean everything as long as there is no break-in(breakage) OK, needs to put in perspective and to be patient.
Old 09-21-2014, 09:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
930/66's Avatar
New Turbo
Brian has given me an answer:
The failure #2 was due to the compressor nut coming loose.
A new turbo wil build and come to me for installing.
Old 10-11-2014, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Hello Thomas,
Tant mieux, maintenant tu sais pourquoi tu as eu ce problème, la joie est de retour !
Old 10-11-2014, 09:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
proffighter's Avatar
You lucky b... Finally you will succeed! Thumbs up for Brian as well.
Roland
930 Turbo '81 Too many modifications to list
Old 10-11-2014, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
930/66's Avatar
2.New Turbo
Some Weeks ago ich have received a brand new Turbo from Brian.
Thanks again for your support!!!
after 1300 miles i recheck the valve clearance, all good.
I let you now when i make my first test drive with the new turbo
Old 11-27-2014, 12:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
930/66's Avatar
It goes on
So the second new turbo is in the Car, he is different to the first one....
Hotside is smaller / Coldside as before:
Old new
New
K27 has 2 Version
Old 01-17-2015, 07:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
