Rarly8 Headers Change Silikon hoses to Aluflex
The Silikon hoses with the heat insulation tape was not mine.
I have made an aluminum adapter for the Aluflex. but first comes the 3ldz out ![]() ![]()
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Adapter for Heater Box (new all in Black)
New Paint in black with Adapter
![]() ![]() New K27/29 ![]() ![]() ![]()
Even if I prefer raw, black looks beautiful. Nice work!
Roland 930 Turbo '81 Too many modifications to list |
Thanks Roland
New Aluflex Tubes
I like the Aluflex vs Silikon Tubes (with heat Tape)
Modification Air Filter Box
I still had problems with the fitting between the TK intercooler and the Air Filter Box.
Again i cut some Piece out and fix it together. ![]() ![]() ![]() ![]() ![]()
First Drive with the New K27/29
The First Drive with the "new K27/29" was good
, no Problems.The difference of the different exhaust turbine is very noticeable. I have the Data from Zeitronics as the compressor nut coming loose (3.Gear)
Current AFR Results
My current AFR results looks not to bad.
![]() ![]() I must do test runs at maximum speed and full boost to see this afr situation. First i recheck all pressure from the CIS and make a flow testing from the injektors.
Do you have a design or a build sheet for your engine/tranny rest? I'd love to make something similar for when I need to drop the tranny and motor.
~Andy
1983 Porsche 911SC Blk/Blk 1956 Ford F1 - Patina 2013 Toyota Tundra 4x4 5.7 2013 Honda Pilot |
AFR of 14.1 - 14.2? Too lean. That is with no boost and low rpm but no room for error there.
I'm sorry I do not have a plan of the design or a build sheet. My Friend has it continuously constructed by hes engine build. The base is a motorcycle hydraulic ramp. Thomas
In the second and third diagram you must take the values from the vertikal line.. for example: Idle 4531 / Boost 099 Bar / AFR 12.4
Got it, looks good. So over about how much time does the 3rd graph cover? You've convinced me to get a Zeitronix for my build. It's cheap compared to dyno time for tuning.
FAST test saves lives
black pipes
Yes i think the Zeitronics is a god solution (i have the little Blackbox) it helps, but a dyno is a must for me in the final.
Subscribed
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Having a similar problem with my k27HFS. I will look into the same methods of testing as well. I do not have a turbo to swap out though. Thank you for such a detailed build. Nice work.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Thank you for your kind words!
CIS Testing
CIS Test:
System pressure was too low: ![]() I have ordered a new system pressure regulator to fix the Problem
Installing Fuel Pressure Regulator and Damper
I have also ordered the Fuel Pressure Diaphragm Damper (was installed in the 930/66 S)
New Parts: ![]() ![]() ![]()
