I ordered the better tip that heats faster. I'll have that on Wednesday and we'll see what happens.
Matt. 83 911SC 85.5 944 NA - Sold |
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I slid a nut over the stud till about 2 inches above the case and mig welded it from both sides. heated the case 15 minutes with the torch. (use plain steel nut). Put a ring spanner and an 1.5 foot breaker bar on it. On the ones broken off just above the case I put a washer onto it to protect the case and mig welded also a steel nut on it. Heated the case again for 15 min. All 24 studs came out including the 7 broken dilivar studs. When I delivered my parts to the machine shop the owner said to me " We put the case in an oven and take them out for free as we hate solving client mishaps" Still very satisfying to have done it myself.
You need to add thread penetrant into the above equation (same as for removing exhaust system fasteners) It helps dissolve any metal corrosion and reduces friction between the threads. I use Kroil, but other brands are better than nada.
Sherwood |
I've been hitting it with PB Blaster. Yesterday I received the recommended torch for my map gas canister. The flame is much bigger than my other torch. So hopefully I'll get to try it tonight.
Thanks guys! That worked!!
![]() ![]() On to the next step! Sent from my iPhone using Tapatalk
For how long did you need to heat?
'90C4 |
i bet a while, that bugger started to twist, i had on of those too , it seems every engine gets one ..
at the factory .... " remember guys, put that super epoxy on one stud on every engine to discourage those DIY guys " lol
Thanks for recommending this torch. It's my new favorite tool. I was having trouble removing the pulley bolt. My 1/2" electric dewalt wasn't breaking it free. And that thing is powerful. I soaked in PB blaster overnight. Hit it with the torch today for a few minutes. And I spun it right off. Ready to split the case.
Glad it worked out for you. It's great for lighting cigars too!
Whoa. Cool.
![]() Sent from my iPhone using Tapatalk
