Poll: At what mileage did your R1100S clutch require reconditioning?
Poll Options
mosearch's Avatar
R1100S Clutch Service life Poll
I'd like to get a bead on how long our R1100s clutches are lasting...please "vote".
Everybody loves big twins.
Old 09-23-2019, 09:19 AM
36,000 miles still original
Old 09-23-2019, 09:22 AM
unsafe at any speed
wswartzwel's Avatar
54,000 miles lots of wheelies and abuse... still original.
Bill Swartzwelder
Old 09-23-2019, 10:57 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Don't think mine will ever wear out. I don't and haven't done that kind of riding. I just get it into 6th gear and cruise.
Clutch wear may be more a regional thing.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 09-23-2019, 11:48 AM
R1100S2000's Avatar
Only replaced mine @ 50k miles due to rear main seals.
Ryan
'23 R1250RS, '99 R1100S, '98 CB750, '88 K75S, '74 CB360, '70 CL450 Café Project, '81 Yamaha 250, '05 S2000, '08 RDX Turbo
Old 09-23-2019, 12:16 PM
My clutch splines failed at 45,500 miles. That is the only reason I replaced the clutch. It was fine until then.
Old 09-23-2019, 03:15 PM
35,000m. Done with spline lube. There was still meat on the bone but I figured better do it. Many, many miles on the bike as a USCF moto marshal in bicycle races - that can be tough on a clutch (two up on the Manayunk Wall following riders in the Philly Classic)
Old 09-23-2019, 03:30 PM
Life of a clutch
156,000 kms, almost 100k miles on original clutch. I pulled the trans at 40k kms to lube the splines. I pulled the starter and had peek the other day. More than a bit of play between the disc and shaft. Me thinks times up.
Old 09-23-2019, 04:20 PM
How much play, measured at the edge of the disk?
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 09-24-2019, 01:16 AM
clutch life
About 2mm between shaft and hub. I neglected to ensure the splines went back in precisely the same position when I pulled the trans. This may have accelerated the wear.
Nonetheless 100k is pretty good. The trans shifts perfectly, I could keep riding, and wait for bang. I'm going to pull it, put new input shaft and disc.
Old 09-24-2019, 09:11 AM
I wouldn't do it. 2 mm is normal wear. 8-10 mm is an impending failure. Check it every 10K miles and you'll be fine. Really.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 09-24-2019, 09:53 AM
clutch life
Thanks for the advice . I guess I'm spooked by all the "hysteria". I know you've wrapped your head around this as much as anyone. "Ride On".
Old 09-24-2019, 02:05 PM
It's simple, really. There are good ones and bad ones. If yours hasn't torn itself apart at 100K miles, you have a good one. That's great. Ride it and forget it. Check it every now and then if you simply MUST do something. (Believe me, I know the feeling.)
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 09-24-2019, 04:06 PM
+1 normally around the 100mph
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 09-24-2019, 11:26 PM
RBMann's Avatar
1st-60,000 miles on the original but replaced because the disc friction material was worn and causing it to slip.
2nd-45,000 miles and replaced because the disc splines were worn but the transmission shaft had some small wear.
3rd-? miles still in use.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 09-25-2019, 10:54 AM
unsafe at any speed
wswartzwel's Avatar
I thought you quit smoking?
Bill Swartzwelder
Old 09-25-2019, 11:02 AM
Spline failure prompted my clutch replacement cause it was a good idea at the time.
Old 09-26-2019, 12:05 PM
RBMann's Avatar
Yeah, gave up years ago. Now I am into weight lifting with the AT.
Old 09-26-2019, 12:11 PM
