Originally Posted by shreddr View Post
Hi Scott, you can run the stock rods as long as the wrist pin holes are in the same location relative to the piston deck (top). Wossner had made a high performance “kit” that utilized 3mm longer rods (128mm c-c) to slow down piston speed, and reduce forces towards the cylinder walls. If you have the pistons with the relocated wrist pins you will need the longer rods.
Thanks Shreddr.
Old 01-06-2022, 03:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
No try, do or not do
shreddr's Avatar
I should also mention that you should get the 103mm head gaskets before you do anything, because they are hard to get, and mandatory to the modification. No head gaskets, no go!
2017 R1200GSW Rallye Shreddr Signature Model
Old 01-07-2022, 06:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Hi Shreddr,
Thank you for the heads-up, have you any suggestions on where I might look for a 103 gasket kit?
Old 01-08-2022, 06:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
shreddr's Avatar
Big Bore kit for the BMW DOHC engines
Mine were a gift from Fralind, the patron saint of boxer motor modification I do recall they came in a Wosner package, so you may start with them. If you can’t get them from Wosner, Cometic makes custom gaskets, but they won’t be cheap.
Old 01-09-2022, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Hi Shreddr,
The mechanic has come back with concerns over the width of the cylinder lining, particularly with boring it out to 102.96mm.
In your experience has there been any problems with the Wossner modification I am about to make making the lining too thin?
Old 01-09-2022, 04:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
shreddr's Avatar
I just realized you are talking about the R12S, I thought we were talking HP2S. Your mechanic is right, the R12S can’t be bored to 103mm. I forget what the diameter is, but if you do a search on the forum you can find it. In reality you can make huge improvements just by swapping pistons and rods for the Wossner hi compression kit, I think the combined weight savings was almost a pound of rotating mass, combined with a performance full exhaust (cat free header) and a good ECU tune will unlock lots of power without the need to do the bore job.
Old 01-09-2022, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Yikes, I was told it was doable - I'll see if I can cancel the order.
Old 01-09-2022, 05:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Hi Shreddr,
To your knowledge - Is there a high compression piston kit available that runs on the standard length Con Rods (125mm) as I don't think they make the 128mm rods anymore.
I have heard the HP2 rods which are 128 fit the high compression pistons??
Thanks for your help.
Old 01-09-2022, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
shreddr's Avatar
Originally Posted by NZHP2 View Post
Hi Shreddr,
Hi Scott, I modified my R12S quite a while ago and at the time I got everything straight from Wosner. I don’t know where you are located (New Zealand?) but if I were trying to do the same thing again, I would tear down the R12S and send the stock pistons and rods to CP-Carillo and have them custom make a high performance set. IMHO you can’t do much better.
Old 01-10-2022, 04:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
shreddr's Avatar
I just read through this thread again, the R12S is capable of being bored to 103, the HP2S can be bored to 105. Your pistons will work, I still recommend getting the gaskets first, and if you want to forgo the bore job, the CP-Carillo custom kit is still your best bet.
Old 01-10-2022, 06:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
Droptarotter's Avatar
Hey Shreddr, good to see you are still alive and active here!
Hope you are well!
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 01-13-2022, 08:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
shreddr's Avatar
Hope you are well!
Cheers
Hi Bryan, how’s things?
I get notifications on my past PP posts, so I drop in every once in a while. I am only motoing on my GS so I spend most of my forum time in ADV but I definitely have a soft spot for the Pelican nest
I really dig the upright riding position of the adventure bikes, and I don’t feel the need to “speed” anymore, which is a good thing.
I have also jumped in with both feet on ebikes after getting both hip joints replaced, and have been raging on my homegrown dualie. Give it a try, it’s a game changer.
Old 01-14-2022, 01:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
milnersXcoupe's Avatar
HP2 cylinder spigot case bore / case stud locations
Originally Posted by pmc847 View Post
What is the difference between the R1200 and the HP2 cylinders? Are the studs in a different place or is it just the case bores (hp2) are larger to accommodate the 105mm cylinders? If so then I would assume that the R1200 cases could be bored to accomadate the 105mm cylinders. Your thoughts.
Philip
HP2 case stud locations R
spread further apart.
More case material between
bore hole / case stud
R1100 / R1150 cases
tend to crack when involved
in a crash.
Race Bikes Crash
Boring Out Stock Cylinders
is not a good idea
Factory designs in Heat Shedding
& Operating Temp Straightness.
Big Bored Factory Cylinders tend to run Hot
Big Bored Factory Cylinders tend not to run True
If you want a German Road Rocket
install a 3 Stage NOS system
Me-109s & FW-190s had great WOP
success with NOS
Old 01-16-2024, 02:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
kpolito99's Avatar
I purchased the Wossner 103 mm bore kit and have not experienced any overheating issues and it gets pretty damn hot in Tampa, FL.
I did however install the HP2S' larger oil cooler and oil pressure relief spring when I completed my engine upgrades.
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 01-16-2024, 06:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
