Droptarotter's Avatar
Originally Posted by shreddr View Post
almost all of the cable ends are available as spares.
#3 and #9 look very similar to what is used for the heated grips.
#3 should come with the grip, so you will need two #9's.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 12-15-2011, 12:14 PM
No try, do or not do
shreddr's Avatar
i mounted these up to my HP2S, I just need to get to the dealer and have it activated. this was a very easy install. I did the same upgrade on the BCR and had to pull the tupperware, and add a wiring harness into the fuse box, etc it was kind of involved. On the HP2S you swap the grips and the right switch gear, plug into the loom that is already there and you are good to go! it was $400 worth of parts though!
2017 R1200GSW Rallye Shreddr Signature Model
Old 01-01-2012, 04:13 PM
In you climate Jeff, that is $400 well spent.
Old 01-02-2012, 05:02 AM
LeftCoast Peter's Avatar
Hi,
I'm installing heated grips on my HP2S. The plugs to accept the plugs from the grips have been snipped off (it was raced and I guess some tech thought it was a good idea - grr). I have been able to dig out the ends out of the rubber part but I can't identify any colours.
I'm going to attach a plug onto the end of the wires. My question is this: common sense tells my that its a simple resistance circuit - I should be able to attach to either wire without regard to colour. Right?
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 03-13-2015, 05:58 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
If it's just a single pair of wires, then yes, but there's still one ground and the way the canbus works, you never really know. Best to have it wired as it should be.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 03-13-2015, 11:07 AM
Thanks - yes its just a pair. Nice.
2009 525 Beta RR
North Vancouver
Old 03-14-2015, 09:34 AM
I too mounted the heated grips and actually the throttle control remains very accelerated when it should be at minimum. Can you tell me if it is sufficient to adjust the throttle control as indicated below, or is it necessary to resynchronize the system at a BMW workshop?
Thanks!
Old 08-22-2023, 10:21 PM
Thanks!
I don't remember touching the throttle at all, but it has probably been 10 years since I installed my heated grips.
It's possible you got the cable installed incorrectly on the drum or maybe pulled it out near the right throttle body or at the Bowden box.
It's preferable to use a GS911 tool to set the stepper motors while syncing the throttle bodies. That being said, I have balanced the throttle bodies without setting the steppers and the bike ran fine.
You will also need a balancing tool for the throttle bodies.
Cheers
Old 08-27-2023, 03:03 PM
Thanks for your answer.
I compared the two throttle controls and they are different, this is the reason that causes tension in the gas cable. I have adjusted the throttle as indicated in the previous photo and everything seems back to normal, but I will be going to BMW to have the system double checked.
Old 08-29-2023, 10:43 PM
That's odd, I don't remember replacing that part at all??
Cheers
Old 09-07-2023, 07:06 AM
The heated right hand grip includes the gas control, the one purchased new differed in the details I highlighted, BMW probably introduced some variations without changing the identification code of the part....
Old 09-08-2023, 04:53 AM
The BMW service has activated the retrofit for the heated grips without errors, but they do not activate.
1. heated grips and right switch are new.
2. from the BMW computer it is possible to turn on the heated grips and check the electrical signal of the two switch positions.
3. No heated grip icon appears on the display.
Any thoughts on the problem?
Old 09-13-2023, 12:07 PM
You took it to a dealer, had the bike hooked up to the diagnostic computer and still no icon on the dash?
I think in one of my original posts there is the procedure for the dealer to follow??
Was that done?
If so, I have no idea why the grips do not work?
Cheers
Old 09-20-2023, 07:25 PM
The activation procedure has been successfully done a couple of times, but no icon on the dashboard and the knobs do not turn on using the right switch.
We also tried replacing the right switch.
The knobs are switched on only via the BMW diagnostic computer.
Maybe the problem is downstream of the switch...maybe a relay?
Old 09-20-2023, 10:43 PM
Damn! Sorry, now I have no idea??
Seems like everyone else has not had any problems with the procedure??
Maybe a broken wire from the bars where the wires flex near the steer head??
This is a known problem on the 12S as the wires are a very small guage.
Keep us posted!
Old 09-21-2023, 07:35 AM
Thanks, in fact I seem to be the only one having problems...I will take the bike back to the mechanic for another check.
Old 09-21-2023, 11:43 PM
Eureka!
I solved
No defects or electrical interruptions, I armed myself with ODB LX diagnostics + Motoscan app and activated the knobs... which were deactivated.
It remains a mystery why BMW didn't succeed.
Old 10-02-2023, 11:16 AM
Well done! Enjoy!
Old 10-05-2023, 04:42 PM
shreddr's Avatar
Eureka!
I solved
I forgot how cool the HP2S dash looks
Old 10-07-2023, 11:37 AM
