Droptarotter's Avatar
HP2 Clutch Fluid
Hey gang;
I'm stuck at work and need to pick up the correct clutch fluid for the HP2 on my way home.
I believe it is mineral oil, but what????
I don't know if I will be able to make it to the dealer....so any other suggestions???
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 05-10-2013, 08:41 AM
unsafe at any speed
wswartzwel's Avatar
Bicycle shop has it for magura brakes. so do most auto parts stores.
Bill Swartzwelder
Old 05-10-2013, 09:04 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Yeah, the cap says mineral oil IIRC but the rider's manual states DOT4.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 05-10-2013, 09:27 AM
Thanks for the tips guys.......managed to get by the dealer and get the Vitamol v10.
Cheers
Old 05-10-2013, 06:52 PM
I just wanted to let you guys know how easy it is to bleed the clutches no the R12/HP2's.
I picked up the Vitamol V10 at one of the local dealers for $18/250ml. That is bloody robbery, but stick with me......
I used a 10ml syringe and a bit of plastic pipe.......sucked the Vitamol out of the container........put the pipe on the slave cylinder bleed nipple.......opened the nipple and forced the fluid up into the nipple.
10ml did get the fluid into the reservoir, but I still had no clutch........installed a hose on the bleeder at the reservoir and bled it about 5 times........bled the slave once........and now have a nice clutch feel.
I used about 20ml of Vitamol.......so....that $18 for 250ml equates to about 12 bleed jobs........or about $1.50 a bleed job!
If you take it into that context, it's pretty cheap and you are still using the recommended fluid!
Cheers
Old 05-18-2013, 09:13 PM
LeftCoast Peter's Avatar
Can I come by with a toonie and get mine done by the pro?
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 05-19-2013, 12:21 PM
Yeah, but it'll cost you more than a toonie!
Get your own Vitamol, bring copious quantities of beer and don't forget the dancing girls!
Cheers
Old 05-19-2013, 04:26 PM
Be wary of using old brake/clutch hydraulic fluid. The oil is hygroscopic ie it absorbs water and once opened has a very short shelf life. As such a critical component it is good practice to only use new unopened hydraulic fluid as to do otherwise can be false economy.
Old 05-24-2013, 11:11 PM
Registered Agitator
sgoodwin's Avatar
It's mineral oil not hydraulic fluid, it does not absorb water but you could give yourself an enema or drink it for constipation.
Old 05-25-2013, 03:09 AM
unsafe at any speed
wswartzwel's Avatar
Originally Posted by sgoodwin View Post
it's mineral oil not hydraulic fluid, it does not absorb water but you could give yourself an enema or drink it for constipation.
+1
Bill Swartzwelder
Old 05-25-2013, 05:21 AM
