9dreizig's Avatar
Send a message via AIM to 9dreizig
E brake cable removal
I'm installing new rear wheel bearings and axels .. I've got everything off except the e-brake cable.. Anyone have any advice ?? can't seem to get the cable out far enough to remove the pin ..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-11-2023, 03:36 PM
Ummmmmmmmm, what model year are you working on?
Tom Coradeschi
03 Boxster
Old 06-12-2023, 03:26 AM
9dreizig's Avatar
Sorry 2001 Boxter
"Todd"
Old 06-12-2023, 07:34 AM
Thanks. So, my comments relate to my 03, but it should likely be the same for your 01.
You will have to disassemble the parking brake assembly in order to disengage the cable from the actuating mechanism. Who’d have thought that in 2023, you’d have to wrestle with drum brake components (adjusters, springs and all the rest), but you do.
Tom Coradeschi
03 Boxster
Old 06-12-2023, 08:52 AM
9dreizig's Avatar
Tom, I"ve taken those components off already ,, still can't get the cable to the point to un-do the cable. I am wondering if I need to rip apart the whole console to loosen the cable ? ?
"Todd"
Old 06-12-2023, 12:49 PM
Ah. So, if all the parking brake components are off the car, you “just” need to pull the cable off the back of the hub. There is a small stub (#21 in the attached) which is affixed to the backing plate, and the cable slips into it. Corrosion may or may not make that a challenge.
Tom Coradeschi
03 Boxster
Old 06-12-2023, 02:25 PM
