Porsche Crest 3.2 - 3.6 build pictures
Old 09-30-2010, 08:52 AM
Old 09-30-2010, 07:11 PM
Schumi's Avatar
Can't wait to see more!
M
Old 10-02-2010, 06:21 PM
IMS Bearing Inspection
Pulled the Dealer installed updated IMS flange & found the shaft has a good 1/4" freeplay. While trying to remove the bearing seal with a small pick caught the edge of the race & it came out with the seal very easily & ball bearings spilled out with it!
Old 10-02-2010, 08:03 PM
Zeke's Avatar
Can you show more of the bearing and what you found plus what you're doing about it?
Old 10-03-2010, 10:43 AM
Not much to see of the IMS bearing. It is a double row, the external side is on the floor & in last pic. The internal side is not visable without an extraction. I am having LN's triple ceramic upgrade installed.
Old 10-04-2010, 10:32 AM
Old 10-06-2010, 09:40 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by BYprodriver View Post
If you tidy up a bit, you should have room for a coffee maker
Don't know witch one to get??? Check http://forums.pelicanparts.com/off-topic-discussions/568309-new-coffee-maker-thread.html
Who Will Live... Will See
Old 10-06-2010, 03:25 PM
Schumi's Avatar
Guys heres a curious question from me here- what's the technical name for the bottom end aluminum crank carrier? I've heard it called something before, but I cannot remember.
M
Old 10-06-2010, 05:40 PM
Platinum Member
dad911's Avatar
It's called a 'Bearing Housing' in the workshop manual.
Old 10-06-2010, 06:54 PM
txhokie4life's Avatar
You're pictures look like a std 3.2L
Did you bore it out and replace with Nickies to 3.6L?
or are you putting in a dual vario-cam 996 3.6L engine?
If so what are you doing electronics wise?
thanks,
mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 10-06-2010, 09:54 PM
Schumi's Avatar
Mike-
I think that's the engine coming out of the standard S... not the 3.6 going in.
M
Old 10-06-2010, 10:00 PM
thanks,
mike
This is the original Bearing Housing, it gets cleaned,inspected for wear & new DFL coated bearings & endplay shims.
Case gets 99mm LN Engineering sleeves.
One of the many advantages to building original engine is no electronic manipulation is required. This is the original 3.2 case. Bearing housing is in previous post photo.
Old 10-07-2010, 09:42 AM
Old 10-09-2010, 09:00 AM
Shiny stuff is here!
Old 10-11-2010, 11:15 AM
Schumi's Avatar
What kind of cams are going in?
M
Old 10-11-2010, 12:01 PM
The original cams for emissions compliance & low rpm torque!
Old 10-12-2010, 09:35 AM
Old 10-13-2010, 10:51 AM
Wow...someone done a good job on the heads...is that new valves as well?
Keep the pics coming......
Old 10-14-2010, 01:17 PM
Flat6innovations with new valve springs & swirl polished valves
Old 10-14-2010, 11:21 PM
