bossifrance (guest)
Guest
Posts: n/a
Your information made it a lot easier to choose between the Boxster and the MX5 ! sorry Porsche
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Old 11-26-2011, 04:55 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmmm, my guess is that you haven't had the opportunity to drive a Boxster? Most people who actually drive them end up choosing them. In my opinion, there is no comparison between the two.
- Wayne
Don't be afraid of the Boxster! Oh, wait I see France in your name, NeverMind!
HK
Old 11-26-2011, 06:46 PM
ronster's Avatar
Whose information are you referring to when you say "your?"
Old 11-26-2011, 07:00 PM
Inquisitive user
randy_k's Avatar
Wink
OK, I'm confused. The title of your thread starts with "Question". But what you posted in the first post is a statement.
Anyway, I've driven both and I'll keep my Boxster. Plus the Boxster is easier to work on IMHO.
Don't be scared. Come on over to the dark side.
Randy
Perpetual change. It will happen!!!
Old 11-27-2011, 08:25 AM
This is my first post.I have a question for someone. I have 99 boxster, about 60k mls it was running great, i turned it off and when i stwent to start it i heard a snap and the engine was locked up. I rolle the car back and forth and it turned over and started but something was broke , it sounded bad ,i turned it off and towed it home. Since then i changed ims bearing it still sounds bad, any suggestions? thks
Old 11-27-2011, 09:44 AM
Alphaboy1's Avatar
Which motor is this? Also where is the noise coming from? More details might help.
Regards
Paul
Old 11-27-2011, 11:36 AM
Inquisitive user
randy_k's Avatar
Including, Stick shift or Tip, Does it also run poorly as well? Etc...
Old 11-27-2011, 11:46 AM
i believe it is a 2.5 996. It sounds like a timeing chain in front of motor, but i diidn't run motor long i didn't want to damage motor. now i have motor out and ready to tear it down. I was haveing trouble finding manuel for totrque specs and tdc. any suggestions will help thks
Old 11-27-2011, 02:33 PM
Also when troblem occured i heard a snap, like a plastic gide for the timeing tensioner and there were no metal shavings in oil filter and the ims bearing was bad and i replaced it. Could it be the water pump? it is a stick 5 speed sounds like timing chain is slappen around
Old 11-27-2011, 02:39 PM
