Guest
Posts: n/a
Your information made it a lot easier to choose between the Boxster and the MX5 ! sorry Porsche
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987 |
Author of "101 Projects"
Hmmm, my guess is that you haven't had the opportunity to drive a Boxster? Most people who actually drive them end up choosing them. In my opinion, there is no comparison between the two.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Don't be afraid of the Boxster! Oh, wait I see France in your name, NeverMind!
HK |
Inquisitive user
OK, I'm confused. The title of your thread starts with "Question". But what you posted in the first post is a statement.
Anyway, I've driven both and I'll keep my Boxster. Plus the Boxster is easier to work on IMHO. Don't be scared. Come on over to the dark side. ![]() Randy
Perpetual change. It will happen!!! |
This is my first post.I have a question for someone. I have 99 boxster, about 60k mls it was running great, i turned it off and when i stwent to start it i heard a snap and the engine was locked up. I rolle the car back and forth and it turned over and started but something was broke , it sounded bad ,i turned it off and towed it home. Since then i changed ims bearing it still sounds bad, any suggestions? thks
Which motor is this? Also where is the noise coming from? More details might help.
Regards ![]() Paul |
Inquisitive user
Including, Stick shift or Tip, Does it also run poorly as well? Etc...
i believe it is a 2.5 996. It sounds like a timeing chain in front of motor, but i diidn't run motor long i didn't want to damage motor. now i have motor out and ready to tear it down. I was haveing trouble finding manuel for totrque specs and tdc. any suggestions will help thks
Also when troblem occured i heard a snap, like a plastic gide for the timeing tensioner and there were no metal shavings in oil filter and the ims bearing was bad and i replaced it. Could it be the water pump? it is a stick 5 speed sounds like timing chain is slappen around
