2001 Boxter S
Originally Posted by philip_damon View Post
Hi Meirschwartz,
Great drawing, very good English. Now I know where to look, I will let you know what I find. But I don't recall a groove on the inner race.
Thanks for the input.
Phil
hi Phil.
was just wondering how it ended up, and if my explanation was helpful.
trying to help another member, and your feedback will be helpful.
thanks.
Meir.
Old 10-18-2012, 12:50 PM
turboflyer's Avatar
Originally Posted by Meirschwartz View Post
its a little hard to explain with my English.
i hope my drawing skills are better (not sure).
the Red line will represent the grove, located on the inner "ring" of the CV joint.
ignore the proportion of the drawing. whats important is to understand the location of the grove on the inner part of the joint, and the fact it is fecing the wheel.
let me know if it helped.
When I did my 01 S the clip goes on the axel , not in a grove in the CV joint. Did I miss something?
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 11-18-2013, 11:23 PM
2001 Boxter S
Hi turboflyer.
You are correct. The clip slides on the axel grove.
The grove on the CV joint, just indicate the right direction to slide it on the shaft.
Both sides of the CV looks identical (except for the grove). I noticed that once the grove is facing towards the center of the shaft, it will slide easyer.
Old 11-19-2013, 04:38 PM
turboflyer's Avatar
Originally Posted by Turd View Post
I removed and replaced my drive shafts for my 01 Boxster S but used full new replacement driveshafts complete with boots for $128.00 each and saved all the muss and fuss. So glad I researched and found the full replacement. Best extra couple of $ I have spent so far on the "Turd".
Please do tell where you purchased new drive shafts for 128 each. You don't mean the entire axel assembly Right. Just the bare axel? If you did I think that was the find of the year.
I think I paid about 80 each just for the CV inners. Outers not available. Complete from porsche 850 each.
Old 11-22-2013, 02:15 PM
2001 Boxter S
not to speak in turd's name, but i assume he used an aftermarket part.
you can find it even cheaper on some parts websites.
Old 11-22-2013, 02:22 PM
turboflyer's Avatar
Hi turboflyer.
There were no groves in my CV joints. Both sides the same as far as I remember. Grove in the axel, clip sets and will turn in that and sets against the CV, joint but not in a grove in the CV joint. Did I miss something or are they possibly made different by year or actual CV manufacturer?
Old 11-22-2013, 06:27 PM
