Oz (guest)
Guest
Posts: n/a
2005 Boxster S Tiptronic.
Driving at any speed the engine suddenly has no acceleration - the engine revs drops to idle, when I push accelerator pedal down the revs go back to normal. Intermittent annoying problem.
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-28-2014, 05:24 PM
Nick at Pelican Parts's Avatar
This could be a faulty sensor, causing reduced throttle. I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
