Can Any one tell me if it Is possíble to use the Stock 5 speed transmission with a 3.8l engine. The transmission is the original one that câme with the 97 boxster. The engine is a custom built 3.8l.
gearhead
As long as the 3.8 isn't a DFI engine. When they went DFI the bell housing bolt pattern changed.
Now longevity of that gearbox is going to be another thing. If you can find and afford a 6spd you'll be much better off. |
Another question: Will any 6 speed couple up with the 3.8; what modification should I be aware of. Could I change the gear ratios and continue using the 5 speed? What is the issue with the 5 speed longevity?
5speed trans don't last long behind 3.4L or larger.
Schnell Gelb
Just a suggestion - before you fit the used 6 speed - fit new pinion bearings and check/replace the dog teeth on 2nd gear. Lots of info. on this issue here and other similar Forums.
2001 Boxster S Engineers muse |
n, thank you for your help and suggestions. Will discuss this matter seriously with my mechanic.
What other parts besides the transmission is involved in switching from a 5-speed to a 6-speed?
What other parts besides the transmission are involved in switching from a 5-speed to a 6-speed? Shifter? Half shafts?
