Porsche Crest Boxster 5 speed transmission used with a3.8l engine
Can Any one tell me if it Is possíble to use the Stock 5 speed transmission with a 3.8l engine. The transmission is the original one that câme with the 97 boxster. The engine is a custom built 3.8l.
Old 12-27-2014, 07:06 AM
gearhead
As long as the 3.8 isn't a DFI engine. When they went DFI the bell housing bolt pattern changed.
Now longevity of that gearbox is going to be another thing. If you can find and afford a 6spd you'll be much better off.
Old 12-27-2014, 07:58 AM
Thanks for your reply.
Another question:
Will any 6 speed couple up with the 3.8; what modification should I be aware of.
Could I change the gear ratios and continue using the 5 speed?
What is the issue with the 5 speed longevity?
Old 12-27-2014, 09:00 AM
Another question:
5speed trans don't last long behind 3.4L or larger.
Old 12-27-2014, 09:30 AM
Schnell Gelb
Just a suggestion - before you fit the used 6 speed - fit new pinion bearings and check/replace the dog teeth on 2nd gear. Lots of info. on this issue here and other similar Forums.
2001 Boxster S
Engineers muse
Old 12-27-2014, 09:52 AM
n, thank you for your help and suggestions. Will discuss this matter seriously with my mechanic.
Old 12-27-2014, 05:50 PM
What other parts besides the transmission is involved in switching from a 5-speed to a 6-speed?
Old 12-28-2014, 11:46 AM
What other parts besides the transmission are involved in switching from a 5-speed to a 6-speed? Shifter? Half shafts?
Old 12-28-2014, 11:48 AM
