Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
p/s repair (guest)
Guest
Posts: n/a
when does the p/steering come on ? does it stay on when engine is running or only ON DEMAND ? is their a relay externally....can U buy the control module separately@ where? thks 2002 base #wmwrc33402tc35580
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-24-2017, 08:07 AM
Nick at Pelican Parts's Avatar
It is always running, increasing assist as the wheel is turned. No separate module.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
The only thing part of the p/s system that goes on and off is the power steering fan. Be sure to inspect it and to make sure it's working - you can turn on the AC, which should kick it on. Also, spin it with your hand when you're under the vehicle to make sure it spins freely without any issues.
Rebuilt pumps can be purchased here: 2002 Mini Cooper Base Hatchback - Steering System - Page 1.
More info on the fan here: http://www.pelicanparts.com/techarticles/MINI/48-SUSPEN-Power_Steering_Fan_Replacement/48-SUSPEN-Power_Steering_Fan_Replacement.htm
Old 06-08-2017, 11:49 AM
