Guest
Posts: n/a
when does the p/steering come on ? does it stay on when engine is running or only ON DEMAND ? is their a relay externally....can U buy the control module separately@ where? thks 2002 base #wmwrc33402tc35580
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
It is always running, increasing assist as the wheel is turned. No separate module.
- Nick |
Administrator
The only thing part of the p/s system that goes on and off is the power steering fan. Be sure to inspect it and to make sure it's working - you can turn on the AC, which should kick it on. Also, spin it with your hand when you're under the vehicle to make sure it spins freely without any issues.
Rebuilt pumps can be purchased here: 2002 Mini Cooper Base Hatchback - Steering System - Page 1. More info on the fan here: http://www.pelicanparts.com/techarticles/MINI/48-SUSPEN-Power_Steering_Fan_Replacement/48-SUSPEN-Power_Steering_Fan_Replacement.htm |
Thread Tools | |
Rate This Thread | |
